How do I get to the movie info screen using the apple remote? I know I can press "I" on the keyboard but id rather not have to get it out just for this.
Press and hold menu, then select "info" from the context menu.
Alternatively, you can also change the default select action from "Play" to "Show info" in XBMC's settings (under Videos -> File lists).
Thanks. Thought I was going to have to lay out some more money for a Harmony.
I use to run XBMC on second screen while doing other stuff on primary screen. When using Apple Remote, button commands work nicely in the background but pressing remote's menu-button activates XBMC window. Can this behaviour be changed somehow so that the menu-button worked in the background as well?
