2013-07-31, 14:57
Hi (newbie alert)
I'm trying to run XBMC (12.2-3 64bit fedora) under Qubes-OS R2Beta2 (current)
(this is Xen based desktop OS for multiple security isolated VMs based on Fedora 18)
I have installed OK, but on startup it crashes out after a momentary black screen
Starting from the command line gives
> /usr/lib64/xbmc/xbmc-xrandr: Failed to get size of gamma for output
> default
> Running DIL (3.22.0) Version
> DtsDeviceOpen: Opening HW in mode 0
> DtsDeviceOpen: Create File Failed
> default
> /bin/xbmc: line 137: 3112 Illegal instruction (core dumped)
> "$LIBDIR/xbmc/xbmc.bin" $SAVED_ARGS
> which: no lsb_release in
> (/usr/lib64/ccache:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/user/.local/bin:/home/user/bin)
> Crash report available at /home/user/xbmc_crashlog-20130731_090806.log
Inquiring with Qubes-OS forums, it may have to do with "xrandr".
Qubes-OS uses a dummy driver in the VM's Xorg, which doesn't support xrandr extension.
Is a way to disable it, or other workaround possible ?
Thx
IP
> default
> default
Thx
IP
