Hey folks,
I will soon order the components for my HTPC. I think I will use XBMCbuntu as OS.
Here is the config I have in mind:
Box:
Node 605
CPU:
A4-3400
Memory:
Gskill 4Go
PSU:
beQuiet
HD system:
ADATA 32 Go
HD storage: 2 * WD red 3To
Motherboard:
ASRock
DVD:
LiteOn
So do you see any clashes with this config and XBMCbuntu ?
Furthermore, is an SSD of 32 Go enough for the system ?
best,
Yes, get something with an nvidia graphics solution. AMD do not properly support linux.
Or an Intel solution, or anything but AMD.
Ouch :c
Thanks for your answer, unfortunately I already have the motherboard, therefore my set-up is FM1 dependent...
I went through ubuntu forum, as well as AMD and there are some workaround apparently for the installation of the drivers from AMD / ATI.
Furthermore, people were able to install ubuntu on a A6-3400 config quit easily.
So I agree, it is still risky, but I don't really have the choice here.
If ubuntu is really not workong, I can try with other distro and install XBMC later on ?
XBMCbuntu Does work on well on AMD . I did run it on my Htpc with FM1 motherboard and an A4 3400, worked out of the box . the only con i saw (if it matters to you ) is no HD audio support , meaning DTS-HD MA etc..., It was a great setup , log off log on to get to a desktop whenever needed .And worst case if U do need to add the HD audio in the future , you can always add a Fanless Nvidia GPU for 30-40$, and disable the onboard Gpu .
And for the 32gb ssd: Yes it's enough . i m also running a 32 gb kingston , enough for windows O.S , Ubuntu desktop etc.. As long as you don't store your media on it you should be fine
I'm please too see that XBMC works well for you on a similar config
About the sound issue, I plan to add (later on) a dedicated sound card, so that can solve the issue.
But without new GPU / sound card, have you still standard audio output ?
best,
Yep trough hdmi and to my onkyo suround .
1 thing you might have to do is enable the audio on the desktop side . I think it's disabled .
but audio in xbmc works out of the box on the fm1 setup .
Just a quick post to say that the installation went very smoothly
I tried some heavy movie with DTS-HDMA audio, and indeed, the movie is lagging, it is fixed when i switch to stantard audio (2.0).
I will look for drivers though !
I'm very happy with xbmcbuntu so far !
You will NOT get DTS-HD passed through on an AMD GPU on linux. AMD do not support it. They barely support linux at all.
Glad To Hear it !
IF you can , post some pictures of your setup , Don't see enough Nod 605 around .
