Full Version: HVR-2250 no free sequences error
I've been testing XBMCbuntu for a fair while using mythtv as a backend with a Hauppauge HVR-2250 tv card with no real show stopper issues. Slow channel changing but this is a minor point. I've now switched to tvheadend and would every so often get no tv and errors filling up my logs at a massive rate. Errors are:
saa7164_cmd_send() No free sequences
saa7164_api_i2c_read() error, ret(1) = 0xc
tda10048_readreg: readreg error (ret == -5)
Doing research around this is not a tvheadend issue alone. Mythtv gets it as well just never in my myth setup. The only advice I could find was to disable EIT scheduling which in Australia is no good as there are no easy solution for XMLTV.
Has anyone else seen this error?
I have the same problem did you find a solution?
No I haven't yet unfortunately. I've been using mythtv for months without issue but had to reinstall today. Back using tvheadend and this problem comes straight back. So I guess it has something to do with this...
Anyone ever find a solution to this? I am still getting this error from time to time...
