Hi Guys
I am really enjoying this skin, but is there a way to make a addons menu on the home screen.
I know you can make a menu for a favourite item, but I want all addons listed under 1 menu.
Hi Barfish88
Are you thinking "all addons" as in the menu entry item found within the system (settings) menu in order to configure them and so on?
Or
A particular type of Addon (video addons for example) in order to play them?
If it's the second option then you can do that by making the entry "video add-ons" a favourite item (it's listed under the video library) then setting it up as new menu item in skin settings.
Hi Sharpe
I was thinking video addons.
I will try that when i get home, didnt know you could add video addons as a favourite. I only thought you could add a single addon as a favourite.
Oh yeah - it works pretty well. I've set mine up like with some often used video addons as sub menu items under it.
Sorry I am being a noob, when i go to video library all I see are my network folders. No addons
only been using xbmc for a couple of days now
No worries - select "Library" from the videos sub menu - it should be viewable in there.
Sweet working now thankyou.
