Full Version: VNSI4 Android (OUYA)
Pages: 1 2
I've tried to compile VNSI4 for android:
# Instructions from here: http://djk1o.blogspot.de/2013_01_01_archive.html
apt-get install ia32-libs
wget http://www.crystax.net/en/download/android-ndk-r7-crystax-5.beta3-linux-x86.tar.bz2
tar -xvjf android-ndk-r7-crystax-5.beta3-linux-x86.tar.bz2
cd android-ndk-r7-crystax-5.beta3/build/tools/
./make-standalone-toolchain.sh --ndk-dir=../../ --install-dir=/root/android-9 --platform=android-9
cd /usr/local/src
git clone https://github.com/opdenkamp/xbmc-pvr-addons.git
cd xbmc-pvr-addons
PATH=$PATH:/root/android-9/bin:/root/android-9/arm-linux-armeabi/bin
./bootstrap
./configure
make -j2
make zip
./configure --target=arm-linux-androideabi --host=arm-linux-androideabi
On my OUYA I've tried the latest Android-XBMC from today: http://mirrors.xbmc.org/nightlies/androi...bi-v7a.apk
But when I start XBMC I get an error, that the PVR addon could not be loaded and I should take a look in my logfile.
Here's what my logfile says:
19:57:21 T:1733313352  NOTICE: PVRManager - starting up
19:57:21 T:1735053832   DEBUG: int PVR::CPVRClients::RegisterClient(ADDON::AddonPtr) - registering add-on 'VDR VNSI Client'
19:57:21 T:1735053832   DEBUG: PVR - ADDON_STATUS PVR::CPVRClient::Create(int) - creating PVR add-on instance 'VDR VNSI Client'
19:57:21 T:1735053832   DEBUG: ADDON: Dll Initializing - VDR VNSI Client
19:57:21 T:1735053832   DEBUG: SECTION:LoadDLL(/storage/sdcard0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/pvr.vdr.vnsi/libXBMC_VDR_vnsi.so)
19:57:21 T:1735053832   DEBUG: Loading: /storage/sdcard0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/pvr.vdr.vnsi/libXBMC_VDR_vnsi.so
19:57:21 T:1735053832   ERROR: Unable to load /storage/sdcard0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/pvr.vdr.vnsi/libXBMC_VDR_vnsi.so, reason: (null)
19:57:21 T:1735053832    INFO: Called Add-on status handler for '4' of clientName:VDR VNSI Client, clientID:pvr.vdr.vnsi (same Thread=no)
19:57:21 T:1735053832 WARNING: bool PVR::CPVRClients::UpdateAndInitialiseClients(bool) - failed to create add-on VDR VNSI Client, status = 6
19:57:21 T:1735053832 WARNING: bool PVR::CPVRClients::UpdateAndInitialiseClients(bool) - failed to load the dll for add-on VDR VNSI Client, disabling it
The file Android/data/org.xbmc.xbmc/files/.xbmc/addons/pvr.vdr.vnsi/libXBMC_VDR_vnsi.so exists.
Has anyone an idea what I'm doing wrong?
Thanks,
schnere
I try to do the same also using the vnsiserver4..
You made a mistake in adapting the advices of the link, to (cross-)compile the xbmc addons the right way it should look like:
cd /usr/local/src
cd xbmc-pvr-addons
./bootstrap
make
make zip
But in my case this leads to an error with the compiler flags of the json parser.. If I succeed I try to provide the result.
Ok I succeeded with building the addon using the crosscompiler framework.
I had to enable some g++ flags to allow exceptions.. The vnsi plugin fresh compiled for android using the git today (2013/09/02):
http://db.tt/sdoYM7Ws
My build is correct but the xbmc throws the same error you already had..
Other solution could be the xvdr addon, I compiled a fresh version just minutes ago:
http://db.tt/OjhnLm6i
The xbmc xvdr addon is outdated in the android git rep, I tried to merge the newest one withoud success.
https://github.com/pipelka/xvdr-addon-android/issues/1
Ok the xvdr addon for android was outdated because of changing API for xbmc 13 addons.
The regular xvdr addon already fixed this issue, therefore I merged it myself into the xvdr android addon and
finally have a working and fresh build:
http://db.tt/lCzoPCGU
enjoy!
great idea. I didn't think about using xvdr parallel to vnsi. I was able to install your apk successfully.
Now I get the LiveTV channels on my OUYA, but it crashes when I try to watch LiveTV.
Does it work on your OUYA?
Thanks,
schnere
using my last version http://db.tt/lCzoPCGU everything works fine - even HD-TV streaming is no problem for my ouya at all.
You should use only one plugin, I recommend XVDR, (it's a fork of VNSI), because I tried everything else in combination with
the ouya and nothing else worked. If you need help to compile XVDR / VDR feel free to ask and I could provide you a script that does
nearly everything on its own.
I know about XVDR, but I would recommend VNSI as its in active development and the "official" VDR addon.
Furthermore VNSI3 worked really good with my Nexus 7. But the problem I have here is, that the VDR is on VNSI 4 and I can't get this version to work on my OUYA.
So the parallel solution would be great in my case.
May be I should try the XVDR-server version from https://github.com/pipelka/vdr-plugin-xv...its/master . Could be newer than the yaVDR version.
Thanks,
schnere
Could you post the build log of vnsi4?
to compile successfully I had to patch configure.ac :
--- configure.ac        2013-09-14 17:36:12.422813851 +0200
+++ configure.ac.orig   2013-09-14 17:55:16.462812288 +0200
@@ -46,7 +46,6 @@
ARCHITECTURE="unknown"
HOST_INCLUDES=""
HOST_CXXFLAGS=""
-CXXFLAGS="-fexceptions -frtti"
ARCH_DEFINES="-DTARGET_POSIX -DTARGET_LINUX -D_LINUX"
DYN_LIB_EXT="so"
TARGET_LDFLAGS=""
So, I've added the line CXXFLAGS="-fexceptions -frtti"
And here is the build log: http://xbmclogs.com/show.php?id=58610
Thanks,
schnere
I don't see anything wrong on the build.
I think I'll setup a development environment for Android and investigate.
Thanks, would be great to get it working Smile
can you try this branch: https://github.com/FernetMenta/xbmc-pvr-...tree/vnsi4
There was a lib missing at linker stage.
btw: I didn't have to tweak the configure script.
thanks for the fast fix. I will try it later.
If I don't add the CXXFLAGS, I get errors like this:
src/lib_json/json_value.cpp: In member function 'void Json::Value::CommentInfo::setComment(const char*)':
src/lib_json/json_value.cpp:156:4: error: exception handling disabled, use -fexceptions to enable
make[2]: *** [json_value.lo] Fehler 1
Might be, because I compile all modules, not just vnsi?
Thanks,
schnere
Pages: 1 2
