2013-08-03, 11:45
If the option "Adjust display refresh rate to match video" is enabled then custom Video Calibration settings such as pixel ratio adjustment aren't being applied to the video. Turn it off and they are. I couldn't find any threads similar.
1920x1200 screen but only at 1080 so gpu overscan is used to expand the desktop to fill the screen which has to be corrected in Video Calibration. For 16:9 or wider content using another tv mode would be fine with black bars at top and bottom but 4:3 content would still have those black bars.
This is a problem with the panel that could be corrected with a firmware update so it can use the correct resolution but I still think it's a bug.
ver 12.2 on Windows 7 Dual screen
Thanks for any help.
