Full Version: JynxBox - Lost visual of gyro remote
Hardware: JynxBox 4GB - with new remote (the one with numbers)
Purchased box today and have been setting it up.
Had a hard time using the remote until I realized that it needed batteries (was using a mouse and keyboard). (A quick reference instruction booklet would be nice and notification that the remote needs batteries.)
When originally put batteries in it, it showed a pointer on the screen. Performed some add-ons using the keyboard and the mouse, and now tried using just the remote and I do not see a pointer or cursor on the screen. I can more up and down and left and right on the menus, but the pointer was really helpful for quick clicks.
Does anyone know if there are some settings that need to be enabled/disabled to get the gyro pointer on the screen again. (I looked at the settings and didn't see anything obvious.
Thank you in advance for the support and help.
Have a nice day.
Welcome to the XBMC forums.
You may want to contact the hardware manufacturer, distributor or vendor for support of Jynxbox hardware issues. XBMC is just an application.
