I just wanted to say that I have tried both skins and I just prefer ACE!
Its the front screen with the recently added poster view and the vertical menu that does it.
Just my opinion. Both skins are excellent of course!
Anyone else feel the same?
You mean mq4 as mq5 is not out yet.
@bry-, Aeon MQ5, is out, available for
vips, vips with subscription in
xbmc brazil forum (donors) and active translators (
transifex site), but remember it´s WIP skin (Work In Progress), when finished it´s free for all, of course.
Wanilton and Marcos
Bravo Bravo Bravo , for all the skins you have created.
I'm waiting to see MQ5 , but if it is complicated like MQ4 , then i'll remain in ACE.
Fantastic , Easy to use , and it's environment is at the top of the range.
Greetings from Greece
(2013-08-04, 13:31)master345 Wrote: [ -> ]I just wanted to say that I have tried both skins and I just prefer ACE!
The look of MQ5's home screen is very similar to ACE, albeit in an Aeon style.
MQ5's home screen is much more customisable than ACE, but is still a WIP, so it's to early to make a definitive choice IMO.
(2013-08-07, 14:35)Samu-rai Wrote: [ -> ]MQ5's home screen is much more customisable than ACE...
much, much and much more.
Example:
Ace supports up to 12 submneu, total.
Aeon MQ 5:
- menu 1 at 11 = 20 submenu/menu = 220
- video playlists = 15 submenu/menu = 300
- audio playlists = 15 submenu/menu = 300
- addons = 15 submenu/menu = 300
- favorites = 15 submenu/menu = 300
- vnodes = 15 submenu/menu = 300
- others 68 items = 10 submenu/menu = 680
Thus the total number of submenus that Aeon MQ 5 supports is 2400.
(2013-08-10, 14:29)MarcosQui Wrote: [ -> ] (2013-08-07, 14:35)Samu-rai Wrote: [ -> ]MQ5's home screen is much more customisable than ACE...
It means , that the Skin becomes slow to navigate it?
If the skin were written using the base code of Aeon MQ 4, I would say yes, but the Aeon MQ 5 was made under the code of Ace, then it was possible create a super skin that runs smooth.
Aeon MQ 5, you've never seen a skin like this.
Any idea when it's going to release for everyone?
"Phase 3 (scheduled to begin October 1, 2013 - expected duration: two months) - After having a full version, the skin will be published in the open area of Brazil XBMC forum for everyone to have access."
