Full Version: imon display & xbmc
hi all
I have just made a htpc and installed the imon display with rm200 remote control.
Whenever i go into xbmc all it displays is Xbmc [Stop] and 00000000000 for the second line.
I have tried imon on xbmc and it works but when I wake my pc from sleep the remote doesnt work. Once Imon on xbmc is off it work again.
How do i get the display working properly with xbmc.
http://www.soundgraph.com/vfd-feature-en/
Thanks Guys
Dependend on the version of XBMC you are using you should use the official LCD addon instead of the internal LCD function...
see
http://forum.xbmc.org/showthread.php?tid=143912
using windows 7 x64 and xbmc 12.2 recently installed xbmc 13 and now imon.exe is giving me run time errors.
