This is my first time using XBMC, so I am sorry if this is a stupid problem that I am having. I have a Windows 8 desktop that is running XBMC. Using UPNP, I was able to get my Ouya to see the directories on my computer. While using XBMC on the Ouya, when I navigate into a folder where there are video files, no files appear. Any ideas?
Welcome to the XBMC forums.
Did you setup and define the UPnP media source within XBMC on the Ouya?
No I did not nor do I really know what that means. I went to Video, Add Videos, Browse, UPnP Devices, and then my server showed up so I clicked on it. What should I try next?
I got it working. I went back in to UPnP and instead of my server, XBMC was an option. I selected that and I was able to find my files. Thanks for your help!
