Hey everyone, I started working on this again
I pretty much started from scratch and got the basic stuff working for the most part, I think.
Try it out and let me know how it goes. Download and install from zip ->
https://github.com/divingmule/plugin.aud...-0.0.5.zip
There's more features I want to add, favorites and stuff, but this is a start.
(2016-03-10, 16:53)divingmule Wrote: [ -> ]Hey everyone, I started working on this again
Try it out and let me know how it goes. Download and install from zip -> https://github.com/divingmule/plugin.aud...-0.0.5.zip
Thank you - you rock!! Installed, and a couple of quick observations:
- Some channels print garbage (stream info?) on the screen while playing as shown
here
- Searching gives me an error when searching for certain markets. For example, Pittsburgh, PA
Otherwise, working as expected. Thanks again for your work on this. Let me know if I can help further.
Great job! Ironic that just this morning I thought, what the heck, see if anyone has worked on this. Looking forward to the other features mentioned...
Thanks for the feedback!
(2016-03-10, 19:02)downincognito Wrote: [ -> ]- Some channels print garbage (stream info?) on the screen while playing as shown here
Yeah, I hate that
I don't think there is anything I can do from the plugin side of things. Something internal pulls that info from the stream. To bad it's not parsed correctly, the name of the current song and artist are usually listed. If anyone has any ideas please let me know.
Thank you so much for updating this addon.
Great Job!! was missing this so much, Thank You Kindly!!
I am new to all this but I usually do pretty good at this kind of stuff. I can't see how to install this from zip file. When I go to the zip file through kodi, the folder is just empty. Can anyone help out??
(2016-03-25, 15:49)wmtasker Wrote: [ -> ]I am new to all this but I usually do pretty good at this kind of stuff. I can't see how to install this from zip file. When I go to the zip file through kodi, the folder is just empty. Can anyone help out??
Kinda sounds like your using the file manager, just to make sure, do this from the home screen -> system > addons > install from zip file > then browse to the zip file.
I have installed the plugin now on my E2 box, but i have a problem to find my requested station/stream. I want to get this one:
Classic American Top 40
http://www.iheart.com/live/classic-ameri...p-40-6545/
But there is no search function, "only" a list of favorits, but my sream is not included, there is also a menu point named menu where cities listed, but if i selcet them the message after a a few moments of waiting says: "Error! Try another item OR exit and submit log /tmp/e.log. More info in 'Tips' in first screen", doesnt matter which city i select, always the same.
main menu
setup menu with city selction
From where came this list of ratio stations?
How i can add my requested stream?
Is there no search function?
xyladecor That is not the same add-on we are discussing in this thread.
divingmule thanks a lot for the info and the link for the version 0.0.6, which i installed now. But it seems that dont work, if want to start it, i get this message:
i have such a "e.log" file under /tmp, but its empty and dont help very much.
It's working great here. Is there a way tho to make it not switch stations automatically after a while?
Thx
(2016-05-26, 00:38)divingmule Wrote: [ -> ]@xyladecor Yeah cant really help without a log. Normally the log file would be something like /temp/kodi.log I've never seen one that is named e.log, see here > http://kodi.wiki/view/Log_file/Advanced#Location
Yes i understand, without a log its not possible to say anything, have no idea why nothing is written in the log. It seems the only chance i have is to wait, that it maybe runs with an update. Thanks for the plugin and the support, nevertheless!
