Full Version: Sesame Street and Nickelodeon Script Failure
Greetings, I am currently running Raspbmc 12.2 on the rPi. I have installed the Sesame Street and Nickelodeon Add-ons via nixa's repository and the super-repo repositories. Both add-ons install correctly from both repo's but i receive a script failure message from both each time I attempt to access a video. I am running the stock raspbmc skin if that makes a difference or is required to know! Any help or input would be greatly appreciated!!! Thank you very much!
I'm guessing that as far as sesamestreet goes, the website has had a complete overhaul and the scraper in the plugin doesn't work.
I'm working on a new plugin for this website, you can check out progress here:
https://github.com/amitkeret/plugin.video.sesame-street
(It's in very early stages, be advised)
