@everyone:
I'm currently in the midst of moving house so I apologise in advance that I can't get to your concerns as quickly as you (and I) would like. Don't hesitate to report bugs and suggestions etc. etc. as usual -- just have a little patience and understand that I'm very busy at the moment. Once I'm settled into my new place, I hope to be able to resume the same level of support etc. as before.
(2013-09-30, 11:58)efty.edge Wrote: [ -> ]But is it right, that the lower part of the main menu, there where the clock resists, is in white color?
Is it a bug ? Or if not, is it possible to change the color to one like the dark osd!?
Can you show me a screenshot? The dark osd has light coloured text also so I'm not sure what you mean?
(2013-09-30, 15:15)neurosis13 Wrote: [ -> ]I also asked for source flags because HDTV videos (especially TV-Shows) are often cut/censored versions while bluray and itunes videos are mostly uncut/unrated. So when you have those video files and the bluray is released in the meantime you might would like to replace those movies with bluray/itunes versions. There are good reasons while most skins use these flags.
I'm not saying that there are no good reasons for showing source flags - just that when its a choice between showing either resolution or source, the resolution is far far more valuable. The main reason why I think this is because the source is not encoded within the file -- the only way xbmc "knows" the source is because of the way the file is named, so if the file doesn't have the specific naming convention that the skin looks for then the source flag will be incorrect or empty. Also, you can already see a video's filename by pressing info and focusing the refresh button ('writer' changes to 'path').
I was thinking about perhaps if the filename has a match for source in the filename then it would show the source instead of the codec and fallback to the codec if no source string is in the filename. However, I'm probably going to replace the codec info with the aspect ratio once I have something I like for it.
(2013-09-30, 16:03)mikkelnl Wrote: [ -> ]I believe Artic also has this 'question' in its Settings, but I'm not sure (not at home a.t.m.).
Anyways; I really noticed this, in other skins I never have to manually select Subtiles, it simply is highlighted by default
Yeah it was a left over option from xperience1080 -- it never actually worked in Arctic and I removed it from the settings a while back. On one of my systems I use a WiiMote as the control so I don't have buttons for pause, play and info on that one so I use the osd controls for those things. I must be in the 1% that opens the osd for the other options
Like I said before, I'll think about it.
(2013-09-30, 16:50)furii Wrote: [ -> ]would it be possible to have an option to not show logos on the home screen panels? or perhaps tie their visibility to the views > show clearlogo setting already present? i may be in the minority but i actually like the extra space to the right of the plot. if not an option would you mind letting me know what to change to get rid of them on my local copy?
Yeah I think that might be a good idea to combine it as one option. I'll make the changes when I get a chance.
(2013-09-30, 21:33)PatrickBateman Wrote: [ -> ]Thanks for the latest update, being able to add logos manually is a massive plus as I can test/try and create a few and see what looks good and/or just remove them if the blank space looks better
I love the medium + dark OSD for video/movies etc... Is there anyway this exact OSD view could be implemented into the music section too?
It's THE best osd I've ever come across, it's currently perfect! dtshd-ma logos scroll, I'd would b better if they were just elongated, or were the same as dts logo but with a blue "glow" on them (like xp1080)
Yeah if you find any fallback logos that you really like, share them here! Like I said before, they are just placeholders at the moment so I'm not really sure what to use there.
Definitely will be adding the medium osd for music, just haven't had a chance at the moment because I've been so busy. I'll also look at the dtshd-ma logo when I get a chance.
(2013-10-01, 02:42)ghostelement Wrote: [ -> ]I love this skin, but I'm hoping that a couple options can be added in regards to some of the updates. Instead of having to manually edit guisettings.xml, can we just get an option in the skin settings for the Alaska style fade on the homescreen fanart?
Also, clearlogos were added as part of the skin that look like question marks. Those show up when there is no clearlogo detected for movies/tv shows/etc. Can we also get an option to disable that feature? I'd rather just have the blank space there if I don't have a clearlogo. It looks cleaner and less confusing.
At the moment I'm worried about adding too much option bloat, hence why I only provided the option as a manual edit. However, perhaps it could go into the 'backgrounds' section of the skin settings. I'll think about maybe adding it there.
For clearlogos: see furii's post a little up. Basically you can just change them to whatever you want -- they are in the skin.arctic/extras/widgets folder. I put them there for this specific purpose.
(2013-10-01, 09:36)magico77 Wrote: [ -> ]Hi Jur
I really like how the skin is growing up. can you ad the dvd extras add-on? My idea is to mod that ad on to insert in the extra folder the soundtrack of the movie. Do you think is possible to insert a list of mp3 of the soundtrack of the movie?
Yeah will do when I get a chance, just been busy at the moment.
(2013-10-01, 11:28)Scottland Wrote: [ -> ]Not sure if this is a recent change or I've just not noticed it before - but I've noticed an overlay on the home backgrounds related to the colour scheme. Is it possible remove the overlay via editing the xml file in the skin colours folder?
If you are using the simple homescreen you can disable the fade by adding the following to the <skinsettings> section of your guisettings.xml in xbmc userdata folder:
<setting type="bool" name="skin.arctic.home.simple.fade">true</setting>
