(2014-01-06, 03:00)Talguy Wrote: [ -> ]So my problem is only when I'm view my HD channels which are 1000+ channel numbers (fox is channel 1008 in my area).
Edit: Forgot to ask but is there anyway I can set my backgrounds on the home screen to be fanart of TV Shows when hovering over TV Shows and the same thing goes for Movies. In Aeon Nox this was just an option I would choose Called something like "Random Movie" Or "Random TV Show".
Ah I see - I had only accommodated conditions to slide the title over for numbers up to 999 (Australian free to air doesn't even go into the hundreds...) Shouldn't be too difficult to fix. I'll keep you posted.
There is an addon/program that extracts fanart from the library and puts it into folders for tvshows/movies/music etc. but I can't remember what its called at the moment. Basically all you need to do is put the fanart into a folder and then set the background for the respective category to multi image and point it at the folder.
(2014-01-06, 03:35)Tripp Wrote: [ -> ]I figured out what it is. When I have selected a lyrics addon, it tries to toggle that instead of the player controls. Selecting "none" for lyrics brings back "m" audio controls.
Yeah the lyrics addon is a bit of a pain like that. Because it runs as a script (rather than providing the lyrics as an info label) it steals focus.
(2014-01-06, 15:36)warlion Wrote: [ -> ]i been playing with the skin view what do you think?
I wanted to have an option to put the clearlogo at the top but its not feasible because of overlapping with long labels in the now playing info. I like the idea of having an option to hide the labels and show bigger posters instead.
(2014-01-06, 16:52)Maniac Wrote: [ -> ]I was using the skin the other day while watching tv, and said to myself, "damn this is one fine looking user interface"
Thanks!! Glad you like it
(2014-01-06, 18:03)vimarbla Wrote: [ -> ]Have you ever thought about to add the movie duration in the different views? (Sometimes I choose a movie depending on the duration...)
I know there are some views where this value is shown, but I miss it in some of then (my favourites)
Overall I think the year is more useful than the duration in finding a movie out of a list -- what I plan to do for views that show the year in the list is have the # infotag at the bottom show the duration (instead of the year as it does now).
(2014-01-06, 18:48)locomot1f Wrote: [ -> ]@jurialmunkey -- there something funky happening with the visualization screen.
basically, it's not showing up -- or getting hidden.
if I click (M) to bring up the menu screen, it will show up.
if I click on the volume button, it shows up -- for the amount of time that the volume icon is present.
I'm not sure what you mean by 'visualization screen' ?? Do you mean the song info and seekbar etc. that shows on top of the visualization? Maybe you just need to press info (i)
(2014-01-06, 19:25)sling Wrote: [ -> ]What do you use to be able to watch live tv with xbmc?
What can you recommend? I am using cable tv
I don't have cable tv so I can't recommended anything for cable. For Australian freeview (free to air tv via antenna) I use a playtv and tvheadend which works pretty much perfectly on linux. The playtv was made for the ps3, but really its just two dibcom tv tuners in a box that attach via usb.
(2014-01-07, 00:33)jkirk Wrote: [ -> ]I am enjoying this skin a lot and I have a few questions for you as well as a few glitches to report. I am using Frodo 12.3 with 0.6.2 of Arctic and the ServerWMC add on for PVR.
(1) Is there any way to modify the headers so that they just read the category and not the sort method? For example in the image below it reads Movies: Title - can it just display Movies?
(2) Not sure if this is intentional but the star ratings for movies go right to left instead of the more traditional left to right. Is this intentional?
(3) When I try to schedule a timer for a recording in the EPG timeline I get the following popup after I confirm the recording. I do not see this on other skins (Confluence, Quartz) and I am not sure what this is as there are no labels.
(4) When I enter 'Show Information' within the Movies category for a particular film things work fine. However if I use a keyboard shortcut to go to the PVR tools (EPG or Recordings) the 'Show Information' dialog never clears - as you can see below:
1. This is actually a bug -- it will disappear if you turn on the clearlogo in
Skin Settings > Furniture > Show clearlogo. I had completely forgotten about fixing this as I have the clearlogo turned on. I will fix this in the next update.
2. Yeah it's intentional, because the empty stars are so faint I thought it looked weird alignment wise the other way around.
3. This is something to do with ServerWMC - I don't use it so I can't test it (I use linux for a start...). You could try deleting "DeleteTimer.xml" and "RecordPrefs.xml" from the skin.arctic/1080i folder as these are dialogs specifically skinned for ServerWMC and maybe there has been some changes since I skinned those.
4. I'll fix this in the next update.
