grab it from github, and unzip in your addons directory.. will work with gotham, just not from the repo
For me it works already. I find the whole submenu thing instead of going right to the media tediuos though.
(2014-05-09, 11:23)patseguin Wrote: [ -> ]For me it works already. I find the whole submenu thing instead of going right to the media tediuos though.
Just change the setting (either "press up for submenu and press ok for content" or "press ok for submenu")
(2014-05-09, 06:04)ghostelement Wrote: [ -> ]Any ETA on a release for Gotham?
First off it works for me on Gotham final release. Secondly jurialmonkey is hard at work on finishing eminence, finishing school and is working on article mkiii behind the scenes. So please be patient as he is donating his time to us.
Is it possible to have an option to disable the "XBMC" logo from your skin ? I disabled it from general settings because I had 2 logo (frodo/eden/gotham + Arctic).
At least is t possible to replace this old xbmc logo with the new gotham logo on a black patterne (and not grey) ?
Thank you very much
(2014-05-09, 06:06)el_cabong Wrote: [ -> ]grab it from github, and unzip in your addons directory.. will work with gotham, just not from the repo
Does not install for me in Gotham 13.1 beta1. Says dependencies not met when installing as Zip file. Im on newest OSX
Any one else has this?
(2014-05-14, 09:07)jobespierre Wrote: [ -> ] (2014-05-09, 06:06)el_cabong Wrote: [ -> ]grab it from github, and unzip in your addons directory.. will work with gotham, just not from the repo
Don't install as zip, but unzip on your computer and move the folder to ~\*your username*\AppData\Roaming\XBMC\addons
so you get ~\addons\skin.arctic\1080i etc
EDIT: changed the file path, was referring to the wrong one... #$&%! yeah thats a good way to help people..
jurialmunkey
Could u please update to Gotham? Thank friend
Smobbo the subtitle section is not working i think jurialmunkey has to update this skin
@JurialMonkey: Hope all is good with you. Just reporting a small glitch in the detailed extras list screen (VideoExtras add-on).
The flags for the play state and the video lengths are missing; extras image thumbs are showing stretched horizontally as well. They should appear as per image of Confluence (below) or any icons the skinner prefers that could provide the same purpose, as follows:
1) Tick means the video has been watched completely
2) Play icon means the video has been partially watched and is resumable from where it was left.
3) Empty means the video hasn't been watched yet
As per Confluence:
Current missing indicators and lengths in Artic detailed extras list:
(2014-05-14, 21:40)Cashtro Wrote: [ -> ]jurialmunkey
@Smobbo the subtitle section is not working i think jurialmunkey has to update this skin
The subtitle section is actually working, but you can't really see it
If i'm correct you only see the different providers you have installed when you search for a subtitle in a movie/episode. At this point it is actually looking for subtitles at your preferred provider. After a while you can press left and it will show the result, however you don't know when it is done looking for subtitles, or if it has found any until you press left
(and you can't do that until its done, yeah i know a catch22
So it is working, but not very usable
@JM, good luck with your exams and we look forward to your return
There is no widget on simple home screen. My version is arctic 0.6.5
EDIT : issue with skin.widget. Solved with 0.0.29 (see thread)
Am I crazy or is there no way to select 'favorites' in Rom Collection Browser?
(2014-05-14, 09:23)Smobbo Wrote: [ -> ]Don't install as zip, but unzip on your computer and move the folder to ~/userdata/addons
so you get ~/userdata/addons/skin.arctic/1080i etc
This looks amazing so I might try it - but I have gotham. When I extract folder it is named "skin.arctic-master" - should this make any difference to the above process?
