Full Version: how to change default view from Confluence skin?
I don't know if this is something that is already happening, but I could not find it.
In fact I don't even know if this setting needs to be done directly from XBMC and not the addon.
However, a feature I would find extremely helpful is if there was an option to default the "view" to another setting rather than "list".
I much prefer the "Media Info 2" view and when I am going through movies, I have to change the view for every page. Not a huge deal, but would be great if I could be set to default to the view I use.
Thanks again for all the hard work and dedication!
If memory serves me correct, the skin will remember your choice. As for add-ons I believe it it up to the developer. Some will have an option in their settings you'll see numbers like 501, 504, 507 those represent the view setting for the skin. I had found a list a while back, can't remember where, Google should be able to help!
