Full Version: webradio missing from my build
web radio is missing from my current build version 2005.12.19... what is the preferred method to get the lastest scripts? is there any issue with copying old ones over to the new version?
you should download scripts from http://xbmcscripts.com
or you can copy the scripts folder out of your old version.
if you have a customized scripts menu also copy over
xbmc/skin/project mahem iii/pal/dialogsubmenu.xml
