2013-08-14, 04:46
2013-08-20, 10:29
Bump. Would like to know that too.
2013-08-21, 03:31
install latest firmware 1.1.5, after setup you get the launcher selection popup, choose xbmc and click always. Now xbmc will be your default launcher and directly boot to it
2013-08-24, 04:11
Sorry I didn't update this i did get it i updated and install XBMC worked like a charm
2014-02-03, 04:33
Hello! I got my G-Box to boot directly to XBMC. Now how can I undo this, to get it to launch to the selections again?
2014-02-03, 20:59
(2014-02-03, 04:33)Melquiades Wrote: [ -> ]Hello! I got my G-Box to boot directly to XBMC. Now how can I undo this, to get it to launch to the selections again?
Exit out of XBMC so that you're back into Android. Then go to Settings>Apps>XBMC, then clear XBMC as the launcher (can't remember the exact wording).
2014-02-04, 04:18
i think you are talkiing about gbox midnight, the M3 single core ones, right, and you can falsh back into android
http://www.acemax.net.cn/en/shownews.asp?id=126
sorry, you are talking MX2, seems now there are having bugs on the linux version.
you can still reflash back into android version
(2014-02-04, 04:18)kentiger Wrote: [ -> ]i think you are talkiing about gbox midnight, the M3 single core ones, right, and you can falsh back into android
2015-02-15, 01:25
I tried to upgrade to KODI from Midnight MX2 box running android. I uninstalled xbmc and installed Kodi. Now my launcher only has 3d launcher and 2d launcher... neither xbmc or Kodi shows. How do I add KODI to the launcher selection?
