hi,
i have been trying to stream bt sports from an ipod to my xbmc (frodo 12.2) but it doesnt seem to work.
i have airplay enabled in the xbmc settings and it can pick up streams from youtube.
has anyone else managed to get it working
Ideally it would be great if someone could get it to work my windows log contains the following:
19:18:28 T:3820 NOTICE: DVDPlayer: Opening: https://btodhdhlslive-lh.akamaihd.net/i/BT2_2@119327/master.m3u8?hdnea=st=1376763500~exp=1376763530~acl=/*~hmac=bb7cf51a57a8eab403b7d417016c4b2ce0f4ea364c83567b35a5aaf6d0e07083|User-Agent=AppleCoreMedia%2f1.0.0.8F455%20(AppleTV%3b%20U%3b%20CPU%20OS%204_3%20like%20Mac%20OS%20X%3b%20de_de)
19:18:28 T:3820 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:18:28 T:3308 NOTICE: Thread CDVDPlayer start, auto delete: false
19:18:28 T:3308 NOTICE: Creating InputStream
19:18:28 T:3308 NOTICE: Creating Demuxer
19:18:28 T:3308 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
19:18:28 T:3308 NOTICE: CDVDPlayer::OnExit()
19:18:28 T:3308 NOTICE: CDVDPlayer::OnExit() deleting input stream
19:18:28 T:3820 NOTICE: CDVDPlayer::CloseFile()
19:18:28 T:3820 NOTICE: DVDPlayer: waiting for threads to exit
19:18:28 T:3820 NOTICE: DVDPlayer: finished waiting
19:18:28 T:2940 NOTICE: Thread Jobworker start, auto delete: true
incase its of use to anyone...if there's anything else I can provide let me know
try a nightly and see if it is working there...
I've now tried a couple of windows nightly builds, it doesn't seem to work. Just trying to air play iPlayer as well and nothing happens....
bt sport doesn't work in germany - can't investigate. BBC Iplayer (you ment that one?) spits out urls that seem not to work with XBMCs internal player (might be the ssl http stuff which is not working right here).
(2013-08-29, 20:23)Memphiz Wrote: [ -> ]bt sport doesn't work in germany - can't investigate. BBC Iplayer (you ment that one?) spits out urls that seem not to work with XBMCs internal player (might be the ssl http stuff which is not working right here).
Same issues on recent SVT Play (Swedish) streams using my XBMC Online TV (XOT-Uzg.v3) add-on. Install it (
http://www.rieter.net/content/xot/troubl...g/install/) and then select the SVT Play channel and try to playback any recent "Agenda" stream. Those are akamaihd.net streams using HTTPS that should work from any location (using Firefox they work from the Netherlands).
Thats not airplay related - its player related ... thats not my area of knowledge...
(2013-08-30, 17:11)Memphiz Wrote: [ -> ]Thats not airplay related - its player related ... thats not my area of knowledge...
I didn't see the airplay relation in this topic. Will create a new topic then.
