Full Version: Media Remote for XBMC
Get me from Google Play
Play music, watch movies and TV-shows or just listen to your favorite radio station, all remote-controlled by your Android Smartphone.
Tested versions of XBMC: 12.0 - 12.2 (Frodo).
Features:
  • remote-control XBMC
  • modern user interface
  • support of two distinct playlists from XBMC, one for music, one for video
  • browse your media database and add items to playlist
  • push your saved playlists into the active playlist
  • shutdown, reboot or hibernate your XBMC system from your smartphone
  • (beta) support of radio.de plugin, featuring thousands of local and international radio stations
  • (beta) support of tablet sized devices
  • (alpha) support of voice recognition
Planned features:
  • observe selected XBMC systems using notifications
  • support XBMC's picture feature
  • support PVR
  • full support of radio.de plugin
  • support of youtube plugin
  • more colors, different background
  • support specific other media players
What will never be included:
  • Nothing. Everything is possible.
Send me your suggestions and bugs via e-mail, PM or just leave a comment!
Image Image
Latest changes
1.3
  • More Drag and Drop: Move movies, music and episodes from database to playlist
  • More images: Database now shows images to most media items
Introduction to voice recognition feature
Click the microphone button in the upper right corner of your device. If there is no microphone, the feature is not supported by your device.
Say the "magic" word combination:
First: control word
add - Adds the item(s) to playlist.
play - Clears the playlist, adds the item(s) to playlist and starts playing the playlist.
Second: name the type of media
song, album, artist, show, movie
Third: name what to search for
e.g. "David Guetta", "Avatar", "Breaking Bad"
Fourth (only in case of a show):
season x episode y
e.g. "season 4 episode 2"
Some complete examples:
"play artist david guetta"
"play show breaking bad season 1 episode 2"
"add movie avatar"
You may also start a database scan:
"scan audio" or "scan video"
Synonyms and translations:
play - spiele
add - füge hinzu - hinzufügen
song - lied - das lied - ein lied - stück - musikstück
artist - interpret - interpreten - den interpret - den interpreten - künstler
movie - film
show - serie
season - staffel
episode - folge
Introducing v 1.3
Since some new cool functions have been implemented into the app, I want to present them in a few words:
Save playlists
Starting with v 1.2 the application allows to save playlists on your Android powered device. The playlists are saved locally on your device and can't be opened on another remote control, but used with any XBMC you're controlling with your device. Ensure that your database is shared, since the playlist will work only with the same database. Youtube and/or Radio.de playlists will work on any XBMC with the correct plugin installed.
Drag 'n Drop
Also starting with v 1.2, but greatly improved in v 1.3 the app supports drag and drop. Tap and hold on any playlist entry and reorder your playlist or just delete the item. Additionally nearly any database entry can be dragged and dropped into your playlists, allowing to easily organize and order your media.
That are just two of a lot of other new features, but both of these are really mentionable and distinguishing from other remote control applications.
If you like to have some additional features implemented, don't hesitate asking me to add your ideas.[/size]
