Full Version: Configuration
Does anyone know where the configuration files for each emulator core are stored? I'd like to do things like turn off stretching and applying shaders.
stretching is an xbmc setting. Add AspectRatio to keymap.xml (see <FullScreenVideo> here for an example). It should work just like DVDPlayer (haven't tested). Shaders are still on my TODO list.
Each emulator actually has its own specific configuration. In the add-on manager, you can go to an emulator's info screen and hit "Configuration". Right now, the system directory is the only setting, and you don't need to worry about this - if an emulator requires a system directory, it'll automatically ask you for it on game launch. In the future, I'm adding support for the settings that show up in RetroArch.
