2013-08-22, 14:26
I just bought an ATV120 from Geniatech. But XBMC which is embedded on the system doesn't work with Ethernet with uPnP or SMB. I always get "Network is not connected". It seems that if XBMC consider it's not connected to the network, it won't even try to connect.
I found a workaround :
Instead of clicking on the uPnP server, I go to the menu, choose "Play", pause the movie and then click on Now playing to explore the server... but it's not very user-friendly.
Now, my question :
I tried XBMC official 13 beta 6, the bug is corrected, I can browse my server but there is no build of XBMC 13 compiled with amcodec. So davilla, could you explain me how to compile such a build ?
Or is it possible to backport the fixes to XBMC 12.2 ? In System Info, XBMC 13 shows the real IP (192.168.X.X) and correct information about connection, but XBMC 12.2 only shows 127.0.0.1, it can't detect the connection.
Even a "bad" fix would satisfy me, for example, modify the condition
if no network detected -> error "Network is not connected" to
if no network detected -> assume there is network and try anyway
But I don't know which file I should modify.
Thanks for your answers.
Now, my question :
