Hi!
Latest version and ALL version i've tried is crashing when i try to remove a path and apply my change.
Then the program is quiting
Why does this happens?
Using WIndows 8
Any error log?
Check the Ember folder permissions.
Hi!
No log what so ever, can i turn it on maybe?
How to check folder permission?
Thanks fot the tip!
Folder permission: right click on Ember folder and check your permissions.... or try to save Ember outside of c:\programs and c:\user\....
No log file in Log folder?
It works when i have started it as Administrator...
No log in log folder at all. I have put the Ember folder in my Programs folder.
log into windows as admin, got to ember directory and in folder permission setting of Ember program directory make sure to give all users full write acess - you have to do this by hand, usually this is the work of a setup/installer but Ember doesnt have that in moment
