2013-08-23, 10:12
Hey guys,
i want to set up a htpc with xbmc on ubuntu 12.04 but i am running into strange xbmc crashes:
I can't nealy interpret the crash file
XBMC-Crash file:
Do you know how to fix the problem?
Is it a hardware/software issue?
Thank you,
Manjetzger
XBMC-Crash file:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: So 21. Jul 12:06:56 CEST 2013
XBMC Options:
Arch: x86_64
Kernel: Linux 3.5.0-36-generic #57~precise1-Ubuntu SMP Thu Jun 20 18:21:09 UTC 2013
Release:
Distributor ID: Ubuntu
Description: Ubuntu 12.04.2 LTS
Release: 12.04
Codename: precise
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/jan/core (2013-07-21 12:06:56.239802837 +0200)
[New LWP 2384]
[New LWP 2400]
[New LWP 2399]
[New LWP 2421]
[New LWP 2422]
[New LWP 2420]
[New LWP 2409]
[New LWP 2410]
[New LWP 2411]
[New LWP 2424]
[New LWP 2401]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f7bdf79456c in XUngrabPointer () from /usr/lib/x86_64-linux-gnu/libX11.so.6
Thread 11 (Thread 0x7f7bd43b4700 (LWP 2401)):
#0 0x00007f7bdeb4e313 in poll () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x0000000000e49e0a in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#2 0x0000000000e49ed0 in PERIPHERALS::CPeripheralBusUSB::Process() ()
#3 0x0000000001142b71 in CThread::Action() ()
#4 0x0000000001142e21 in CThread::staticThread(void*) ()
#5 0x00007f7be2baee9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#6 0x00007f7bdeb59ccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#7 0x0000000000000000 in ?? ()
Thread 10 (Thread 0x7f7bcb9fb700 (LWP 2424)):
#1 0x00007f7bdb16335f in ?? () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#2 0x00007f7bdb15476c in pa_mainloop_poll () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#3 0x00007f7bdb154dd9 in pa_mainloop_iterate () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#4 0x00007f7bdb154e90 in pa_mainloop_run () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#5 0x00007f7bdb16330f in ?? () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#6 0x00007f7bd9d1fd18 in ?? () from /usr/lib/x86_64-linux-gnu/libpulsecommon-1.1.so
#7 0x00007f7be2baee9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#8 0x00007f7bdeb59ccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#9 0x0000000000000000 in ?? ()
Thread 9 (Thread 0x7f7baf7fe700 (LWP 2411)):
#1 0x00007f7be4775a0a in ?? () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#2 0x00007f7be47754fb in avahi_simple_poll_run () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#3 0x00007f7be47756e8 in avahi_simple_poll_iterate () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#4 0x00007f7be477591d in avahi_simple_poll_loop () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#5 0x00007f7be477599c in ?? () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#6 0x00007f7be2baee9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#7 0x00007f7bdeb59ccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#8 0x0000000000000000 in ?? ()
Thread 8 (Thread 0x7f7baffff700 (LWP 2410)):
#0 0x00007f7bdeb53033 in select () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x000000000072b24e in JSONRPC::CTCPServer::Process() ()
#2 0x0000000001142b71 in CThread::Action() ()
#3 0x0000000001142e21 in CThread::staticThread(void*) ()
#4 0x00007f7be2baee9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#5 0x00007f7bdeb59ccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#6 0x0000000000000000 in ?? ()
Thread 7 (Thread 0x7f7bc4ab3700 (LWP 2409)):
#1 0x0000000000728be5 in SOCKETS::CSocketListener::Listen(int) ()
#2 0x000000000071f3de in EVENTSERVER::CEventServer::Run() ()
#3 0x000000000071f898 in EVENTSERVER::CEventServer::Process() ()
#4 0x0000000001142b71 in CThread::Action() ()
#5 0x0000000001142e21 in CThread::staticThread(void*) ()
Thread 6 (Thread 0x7f7bd26e7700 (LWP 2420)):
#0 0x00007f7bdeb2584d in nanosleep () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x00007f7bdeb53784 in usleep () from /lib/x86_64-linux-gnu/libc.so.6
#2 0x00000000011429b9 in CThread::Sleep(unsigned int) ()
#3 0x0000000000a41bce in CDVDPlayer::Process() ()
Thread 5 (Thread 0x7f7bae7fc700 (LWP 2422)):
#2 0x0000000000a2add2 in CDVDAudio::AddPacketsRenderer(unsigned char*, unsigned int, CSingleLock&) ()
#3 0x0000000000a2c118 in CDVDAudio::AddPackets(stDVDAudioFrame const&) ()
#4 0x0000000000a4804f in CDVDPlayerAudio::OutputPacket(stDVDAudioFrame&) ()
#5 0x0000000000a494a0 in CDVDPlayerAudio::Process() ()
#6 0x0000000001142b71 in CThread::Action() ()
#7 0x0000000001142e21 in CThread::staticThread(void*) ()
#8 0x00007f7be2baee9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#9 0x00007f7bdeb59ccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#10 0x0000000000000000 in ?? ()
Thread 4 (Thread 0x7f7bc72a0700 (LWP 2421)):
#0 0x00007f7be2bb30fe in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
#1 0x0000000000b6e0fd in CXBMCRenderManager::FlipPage(bool volatile&, double, int, EFIELDSYNC) ()
#2 0x0000000000a4fa2e in CDVDPlayerVideo::OutputPicture(DVDVideoPicture const*, double) ()
#3 0x0000000000a50662 in CDVDPlayerVideo::Process() ()
Thread 3 (Thread 0x7f7bd5c76700 (LWP 2399)):
#0 0x0000000000b3e456 in CSoftAE::FinalizeSamples(float*, unsigned int, bool) ()
#1 0x0000000000b3e825 in CSoftAE::RunOutputStage(bool) ()
#2 0x0000000000b43ad7 in CSoftAE::Run() ()
Thread 2 (Thread 0x7f7bd4bb5700 (LWP 2400)):
#1 0x0000000000e4775b in PERIPHERALS::CPeripheralBus::Process() ()
Thread 1 (Thread 0x7f7bd68f3780 (LWP 2384)):
#1 0x00007f7bdfeee26b in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#2 0x00007f7bdfeee2d2 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#3 0x00007f7bdfedbd11 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#4 0x00007f7bdfedd758 in SDL_VideoQuit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#5 0x00007f7bdfeb4215 in SDL_QuitSubSystem () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#6 0x00007f7bdfeb42ce in SDL_Quit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#7 0x00007f7bdfeb48cf in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#8 <signal handler called>
#9 0x00007f7bdf79456c in XUngrabPointer () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#10 0x00007f7bdfeee26b in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#11 0x00007f7bdfeee2d2 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#12 0x00007f7bdfedbd11 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#13 0x00007f7bdfedd758 in SDL_VideoQuit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#14 0x00007f7bdfeb4215 in SDL_QuitSubSystem () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#15 0x00007f7bdfeb42ce in SDL_Quit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#16 0x00007f7bdeaa1901 in ?? () from /lib/x86_64-linux-gnu/libc.so.6
#17 0x00007f7bdeaa1985 in exit () from /lib/x86_64-linux-gnu/libc.so.6
#18 0x00007f7bdf799074 in _XDefaultIOError () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#19 0x00007f7bdf7992be in _XIOError () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#20 0x00007f7bdf79724b in _XReply () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#21 0x00007f7be1fe4bd2 in DRI2SwapBuffers () from /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
#22 0x00007f7be1fe39bb in ?? () from /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
#23 0x00000000011192a9 in CWinSystemX11GL::PresentRenderImpl(std::vector<CDirtyRegion, std::allocator<CDirtyRegion> > const&) ()
#24 0x0000000001073f47 in CRenderSystemGL::PresentRender(std::vector<CDirtyRegion, std::allocator<CDirtyRegion> > const&) ()
#25 0x0000000000f4894d in CApplication::Render() ()
#26 0x0000000000fe50a1 in CXBApplicationEx::Run() ()
#27 0x0000000000fece58 in XBMC_Run ()
#28 0x00000000006ecec5 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
12:00:35 T:140169857415040 NOTICE: -----------------------------------------------------------------------
12:00:35 T:140169857415040 NOTICE: Starting XBMC (12.2 Git:32b1a5e), Platform: Linux (Ubuntu 12.04.2 LTS, 3.5.0-36-generic x86_64). Built on May 2 2013
12:00:35 T:140169857415040 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
12:00:35 T:140169857415040 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
12:00:35 T:140169857415040 NOTICE: special://masterprofile/ is mapped to: /home/jan/.xbmc/userdata
12:00:35 T:140169857415040 NOTICE: special://home/ is mapped to: /home/jan/.xbmc
12:00:35 T:140169857415040 NOTICE: special://temp/ is mapped to: /home/jan/.xbmc/temp
12:00:35 T:140169857415040 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
12:00:35 T:140169857415040 NOTICE: Local hostname: HTPC
12:00:35 T:140169857415040 NOTICE: Log File is located: /home/jan/.xbmc/temp/xbmc.log
12:00:35 T:140169857415040 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
12:00:35 T:140169857415040 NOTICE: Found 1 Lists of Devices
12:00:35 T:140169857415040 NOTICE: Enumerated ALSA devices:
12:00:35 T:140169857415040 NOTICE: Device 1
12:00:35 T:140169857415040 NOTICE: m_deviceName : default
12:00:35 T:140169857415040 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
12:00:35 T:140169857415040 NOTICE: m_displayNameExtra:
12:00:35 T:140169857415040 NOTICE: m_deviceType : AE_DEVTYPE_PCM
12:00:35 T:140169857415040 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
12:00:35 T:140169857415040 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
12:00:35 T:140169857415040 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
12:00:35 T:140169857415040 NOTICE: Device 2
12:00:35 T:140169857415040 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
12:00:35 T:140169857415040 NOTICE: m_displayName : HDA Intel PCH
12:00:35 T:140169857415040 NOTICE: m_displayNameExtra: ALC892 Analog
12:00:35 T:140169857415040 NOTICE: m_sampleRates : 44100,48000,96000,192000
12:00:35 T:140169857415040 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
12:00:35 T:140169857415040 NOTICE: Device 3
12:00:35 T:140169857415040 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
12:00:35 T:140169857415040 NOTICE: m_displayNameExtra: DON DENON-AVR on HDMI
12:00:35 T:140169857415040 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
12:00:35 T:140169857415040 NOTICE: m_channels : FL,FR,LFE,FC,BL,BR,SL,SR
12:00:35 T:140169857415040 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
12:00:35 T:140169857415040 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_DTSHD,AE_FMT_EAC3,AE_FMT_TRUEHD,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
12:00:35 T:140169857415040 NOTICE: load settings...
12:00:35 T:140169857415040 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:00:35 T:140169857415040 NOTICE: loading special://masterprofile/guisettings.xml
12:00:35 T:140169857415040 NOTICE: Getting hardware information now...
12:00:35 T:140169857415040 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:00:35 T:140169857415040 NOTICE: Loaded playercorefactory configuration
12:00:35 T:140169857415040 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:00:35 T:140169857415040 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:00:35 T:140169857415040 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:00:35 T:140169857415040 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
12:00:35 T:140169857415040 NOTICE: Default DVD Player: dvdplayer
12:00:35 T:140169857415040 NOTICE: Default Video Player: dvdplayer
12:00:35 T:140169857415040 NOTICE: Default Audio Player: paplayer
12:00:35 T:140169857415040 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:00:35 T:140169857415040 NOTICE: Log level changed to 0
12:00:35 T:140169857415040 NOTICE: Loading media sources from special://masterprofile/sources.xml
12:00:35 T:140169844320000 NOTICE: Thread CSoftAE start, auto delete: false
12:00:35 T:140169857415040 NOTICE: Running database version Addons15
12:00:35 T:140169826752256 NOTICE: Thread XBMC Peripherals start, auto delete: false
12:00:35 T:140169857415040 NOTICE: Previous line repeats 1 times.
12:00:35 T:140169857415040 NOTICE: Setup SDL
12:00:35 T:140169857415040 NOTICE: Checking resolution 16
12:00:36 T:140169857415040 NOTICE: Using visual 0x22
12:00:36 T:140169857415040 NOTICE: GL_VENDOR = Intel Open Source Technology Center
12:00:36 T:140169857415040 NOTICE: GL_RENDERER = Mesa DRI Intel(R) Sandybridge Desktop
12:00:36 T:140169857415040 NOTICE: GL_VERSION = 3.0 Mesa 9.0.3
12:00:36 T:140169857415040 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
12:00:36 T:140169857415040 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_vertex_program1_1 GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_texture_storage GL_EXT_transform_feedback GL_ARB_invalidate_subdata
12:00:36 T:140169857415040 ERROR: GLX: Same window as before, refreshing context
12:00:36 T:140169857415040 NOTICE: Running database version Addons15
12:00:36 T:140169857415040 NOTICE: Running database version ViewModes4
12:00:36 T:140169857415040 NOTICE: Running database version Textures13
12:00:36 T:140169857415040 NOTICE: Running database version MyMusic32
12:00:36 T:140169857415040 NOTICE: Running database version MyVideos75
12:00:36 T:140169857415040 NOTICE: Running database version TV22
12:00:36 T:140169857415040 NOTICE: Running database version Epg7
12:00:36 T:140169857415040 NOTICE: start dvd mediatype detection
12:00:36 T:140169857415040 NOTICE: initializing playlistplayer
12:00:36 T:140169857415040 NOTICE: DONE initializing playlistplayer
12:00:36 T:140170114270976 NOTICE: Thread CDetectDVDMedia start, auto delete: false
12:00:36 T:140169857415040 NOTICE: UpdateLibraries - Starting video library startup scan
12:00:36 T:140169857415040 NOTICE: UpdateLibraries - Starting music library startup scan
12:00:36 T:140169599125248 NOTICE: Thread CVideoInfoScanner start, auto delete: false
12:00:36 T:140169857415040 NOTICE: initialize done
12:00:36 T:140169857415040 NOTICE: Running the application...
12:00:36 T:140169590732544 NOTICE: Thread CMusicInfoScanner start, auto delete: false
12:00:36 T:140169565652736 NOTICE: Thread Jobworker start, auto delete: true
12:00:36 T:140169857415040 NOTICE: ES: Starting event server
12:00:36 T:140169857415040 NOTICE: starting zeroconf publishing
12:00:36 T:140169599125248 NOTICE: VideoInfoScanner: Starting scan ..
12:00:36 T:140169185314560 NOTICE: Thread CMusicInfoScanner start, auto delete: false
12:00:36 T:140169193707264 NOTICE: Thread Jobworker start, auto delete: true
12:00:36 T:140169590732544 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
12:00:36 T:140169557260032 NOTICE: Thread CEventServer start, auto delete: false
12:00:36 T:140169210492672 NOTICE: Thread CTCPServer start, auto delete: false
12:00:36 T:140169557260032 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
12:00:36 T:140169557260032 NOTICE: UDP: Listening on port 9777
12:00:36 T:140169590732544 NOTICE: Thread Jobworker start, auto delete: true
12:00:36 T:140169599125248 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
12:00:36 T:140170114270976 NOTICE: Thread CRssReader start, auto delete: false
12:00:40 T:140169599125248 NOTICE: Thread Background Loader start, auto delete: false
12:00:43 T:140169193707264 NOTICE: Previous line repeats 3 times.
12:00:43 T:140169193707264 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
12:00:43 T:140169193707264 ERROR: Decode - avcodec_decode_video returned failure
12:00:47 T:140169857415040 NOTICE: DVDPlayer: Opening: /mnt/Filme/Blu Ray's/Iron Man.mkv
12:00:47 T:140169857415040 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
12:00:47 T:140169788159744 NOTICE: Thread CDVDPlayer start, auto delete: false
12:00:47 T:140169788159744 NOTICE: Creating InputStream
12:00:47 T:140169788159744 NOTICE: Creating Demuxer
12:00:47 T:140169788159744 NOTICE: Opening video stream: 0 source: 256
12:00:47 T:140169788159744 NOTICE: Creating video codec with codec id: 72
12:00:47 T:140169788159744 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1920x1080, 72)
12:00:47 T:140169788159744 NOTICE: vdp_device = 0xffffffff vdp_st = 0x00000001
12:00:47 T:140169788159744 ERROR: (VDPAU) unable to init VDPAU - vdp_st = 0x1. Falling back.
12:00:47 T:140169788159744 NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
12:00:47 T:140169788159744 NOTICE: (VDPAU) Close
12:00:47 T:140169788159744 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
12:00:47 T:140169788159744 ERROR: VAAPI - unable to initialize display -1 - unknown libva error
12:00:47 T:140169788159744 NOTICE: Creating video thread
12:00:47 T:140169599125248 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
12:00:47 T:140169599125248 NOTICE: running thread: video_thread
12:00:47 T:140169788159744 NOTICE: Opening audio stream: 1 source: 256
12:00:47 T:140169788159744 NOTICE: Finding audio codec for: 86020
12:00:47 T:140169788159744 NOTICE: Creating audio thread
12:00:47 T:140169185314560 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
12:00:47 T:140169185314560 NOTICE: running thread: CDVDPlayerAudio::Process()
12:00:47 T:140169599125248 ERROR: VAAPI - unable to initialize display -1 - unknown libva error
12:00:47 T:140169185314560 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, no pass-through)
12:00:47 T:140169599125248 ERROR: Decode - avcodec_decode_video returned failure
12:00:47 T:140169599125248 NOTICE: fps: 23.976024, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080
12:00:47 T:140169599125248 NOTICE: Display resolution DESKTOP : 1920x1080 @ 50.00 - Full Screen (16)
12:00:47 T:140169857415040 NOTICE: Using GL_TEXTURE_2D
12:00:47 T:140169857415040 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
12:00:47 T:140169857415040 NOTICE: GL: NPOT texture support detected
12:00:47 T:140169857415040 NOTICE: GL: Using GL_ARB_pixel_buffer_object
12:00:48 T:140169185314560 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
12:06:55 T:140169599125248 WARNING: Previous line repeats 8 times.
12:06:55 T:140169599125248 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
12:06:55 T:140169599125248 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
12:06:55 T:140169844320000 ERROR: CAESinkALSA::HandleError(snd_pcm_wait) - snd_pcm_writei returned -5 (Input/output error)
12:06:55 T:140169844320000 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(1)) - underrun
12:06:55 T:140169844320000 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(1)) - snd_pcm_prepare returned -5 (Input/output error)
12:06:55 T:140169844320000 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(2)) - snd_pcm_writei returned -5 (Input/output error)
12:06:55 T:140169844320000 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(1)) - snd_pcm_writei returned -5 (Input/output error)
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Thank you,
Manjetzger
