Full Version: Multiple Fanarts
HI
Recently installed Ember and it seems to work as it should. However i am trying to install multiple fanarts and there is an option in settings to save fanart in an extrafanart folder. there is also the option to use fanart.tv as a source but none of the options seems to work
i have used both the ember tv and TMDB scarpers and none of them returned any extrafanart, also the folder was never created.
Fanart.tv is definitely broken as it just hangs
has anyone managed to download multiple fanart?
any ideas?
Ember don't support Extrafanarts atm, this is an old relic which was never completed.
But Fanart.tv should work if you have set a valid key in settings.
(2013-08-23, 19:10)DanCooper Wrote: [ -> ]Ember don't support Extrafanarts atm, this is an old relic which was never completed.
Thanks for getting back. Where do i insert the api key? i can't seem to find it
In main settings of tmdb scraper.
