Full Version: Raspberry Pi as MySQL Server
Hi Guys,
i got two machines as MediaServers and two XBMC-Clients.
Now i want to sync the libraries with mysql. Since i dont want one of the Servers running all the time even if i dont use any media from it i thought about using my Pi as a mysql server.
is that possible? is the pi fast enough? and does anyone have a how-to?
thanks for your help,
flo
I've done it before. It's not the fastest but it works quite well and it is relatively easy to set up.
I had it sharing my library to my main HTPC and another Pi.
"not the fastest" is what i dont like to hear... but sure the pi is just not the fastest...
thanks for the fast reply!
(2013-08-23, 16:02)lysin Wrote: [ -> ]I've done it before. It's not the fastest but it works quite well and it is relatively easy to set up.
Well, got it working under an Arch Linux build... for sure not fast enough for my large library.
