Full Version: Frodo in fedora 19 KDE
Hi there,
I tried to install XBMC in fedora 19 under KDE using RPM Fusion when i try to launch xbmc i have the folowing crash
[############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sat Aug 24 00:46:23 WEST 2013
XBMC Options:
Arch: x86_64
Kernel: Linux 3.9.5-301.fc19.x86_64 #1 SMP Tue Jun 11 19:39:38 UTC 2013
Release:
LSB Version: :core-4.1-amd64:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch
Distributor ID: Fedora
Description: Fedora release 19 (Schrödinger’s Cat)
Release: 19
Codename: Schrödinger’sCat
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
00:46:23 T:140685684402368 NOTICE: -----------------------------------------------------------------------
00:46:23 T:140685684402368 NOTICE: Starting XBMC (12.2 Git:Unknown), Platform: Linux (Fedora release 19 (Schrödinger’s Cat), 3.9.5-301.fc19.x86_64 x86_64). Built on Jun 6 2013
00:46:23 T:140685684402368 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
00:46:23 T:140685684402368 NOTICE: special://xbmcbin/ is mapped to: /usr/lib64/xbmc
00:46:23 T:140685684402368 NOTICE: special://masterprofile/ is mapped to: /home/ali/.xbmc/userdata
00:46:23 T:140685684402368 NOTICE: special://home/ is mapped to: /home/ali/.xbmc
00:46:23 T:140685684402368 NOTICE: special://temp/ is mapped to: /home/ali/.xbmc/temp
00:46:23 T:140685684402368 NOTICE: The executable running is: /usr/lib64/xbmc/xbmc.bin
00:46:23 T:140685684402368 NOTICE: Local hostname: localhost.localdomain
00:46:23 T:140685684402368 NOTICE: Log File is located: /home/ali/.xbmc/temp/xbmc.log
00:46:23 T:140685684402368 NOTICE: load settings...
00:46:23 T:140685684402368 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:46:23 T:140685684402368 NOTICE: loading special://masterprofile/guisettings.xml
00:46:23 T:140685684402368 NOTICE: Getting hardware information now...
23:46:23 T:140685684402368 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:46:23 T:140685684402368 NOTICE: Loaded playercorefactory configuration
23:46:23 T:140685684402368 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:46:23 T:140685684402368 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:46:23 T:140685684402368 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
23:46:23 T:140685684402368 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
23:46:23 T:140685684402368 NOTICE: Default DVD Player: dvdplayer
23:46:23 T:140685684402368 NOTICE: Default Video Player: dvdplayer
23:46:23 T:140685684402368 NOTICE: Default Audio Player: paplayer
23:46:23 T:140685684402368 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:46:23 T:140685684402368 NOTICE: Log level changed to 0
23:46:23 T:140685684402368 NOTICE: Loading media sources from special://masterprofile/sources.xml
23:46:23 T:140685684402368 ERROR: Error loading special://profile/RssFeeds.xml, Line 0
Error document empty.
23:46:23 T:140685684402368 NOTICE: Running database version Addons15
23:46:23 T:140685670713088 NOTICE: Thread XBMC Peripherals start, auto delete: false
23:46:23 T:140685684402368 NOTICE: Previous line repeats 1 times.
23:46:23 T:140685684402368 NOTICE: Setup SDL
23:46:23 T:140685684402368 NOTICE: Checking resolution 16
23:46:23 T:140685684402368 NOTICE: Using visual 0x22
23:46:23 T:140685684402368 NOTICE: GL_VENDOR = Intel Open Source Technology Center
23:46:23 T:140685684402368 NOTICE: GL_RENDERER = Mesa DRI Intel® Ironlake Mobile
23:46:23 T:140685684402368 NOTICE: GL_VERSION = 2.1 Mesa 9.2.0-devel
23:46:23 T:140685684402368 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
23:46:23 T:140685684402368 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_ARB_ES2_compatibility GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_internalformat_query GL_ARB_texture_storage GL_ARB_invalidate_subdata
23:46:23 T:140685684402368 ERROR: GLX: Same window as before, refreshing context
23:46:23 T:140685684402368 ERROR: SQL: SQL error or missing database
Query: SELECT idVersion FROM version
############### END LOG FILE ################
############ END XBMC CRASH LOG #############]
[/quote][/php]Please help, thanks.
