Full Version: 2 different fanart views possible
I use XBMC for only 2 purposes.
1. is MOVIES and 2. is a custom menu I made called TRAILERS (this is the hd trailers video add-on plugin).
Both MOVIES and TRAILERS are located in the MAIN MENU of xbmc.
When I m in the TRAILERS menu I setup the view as WALL and when I m in movies I ve set up the view as MULTIPLEX. So far it works the way I want. But the problem is the ART menu. For my MOVIES I want to use the DEFAULT setting in art so the fanart is shown big in multiplex. But in the TRAILERS I want to use the CURTAINS fanart (because it seems that the trailers.net video add-on does not support big fanarts). But I can only use one ART: with this I mean that if I use CURTAINS in TRAILERS, this is also used in MOVIES. Is it possible to use 2 different arts for my MOVIES and my TRAILERS?
No ideas anyone?
