Hi all,
Just a silly question... I can't manage to find the option to remove the header of last albums included in the media library on the homepage.
Has someone the answer ?
System/Settings > Appearance > Skin > - Settings > Home window Options > Show Recently added Albums (deselect this)
Thanks for your answer but I have not this option on my side. Maybe it depends on the skin ? I'm using Frodo with skin Quartz.
Yes, this is skin dependent. For Quartz, try the following: XBMC > Settings > Skin > Home media shelf customizer > Music > Custom image (select this option). This will turn the "Auto populate" option to "Off". You may choose a custom image for the media shelf via the "- Browse for image" option or just leave this option unspecified if you don't want any image.
(Moved this thread to the Quartz subforum)
It's ok with your advice.
Thanks a lot !
