Full Version: Mountain lion problem
Hi
Thanks for your email. I downloaded XBMC from the link which you sent it in the previous email. But the XBMC is not working on my Macbook because of my operation is Mountain lion. There is error which is " “XBMC.app” can’t be opened because it is from an unidentified developer.Your security preferences allow installation of only apps from the Mac App Store and identified developers. " Please let me know how should I use XBMC on my macbook ? I really need to use your application on my computer.
Right click or click while holding down the "Control" key on XBMC.app and select "Open". OS X might ask for a password if you have one set. Then press the "Open" button on the pop-up message. From that point on, XBMC should open normally.
For more info: http://support.apple.com/kb/HT5290
U have a setting that u have to select within mountain lion, i just set this dang thing up last night and forgot what it is called but under preferences there is a section that has 3 choices of how apps are installed,
Follow this link and it should work once ur under the security settings in preferences which is now under the main bar across the top of ur screen:
U have to select to install apps from anywhere!!
https://discussions.apple.com/thread/415...0&tstart=0
And im awesome...
