Run fine. What SSD you thinking?
No idea can you recommend one.
Ebay link says 2.5 sata needed ?
You running windows or openelec?
(2013-08-29, 18:30)jammyb Wrote: [ -> ]You running windows or openelec?
Openelec hopefully
Try it on USB memory stick to start off with.
As it has USB3 get a usb3 stick. That'll fly!!
(2013-08-29, 19:41)jammyb Wrote: [ -> ]Try it on USB memory stick to start off with.
marvellous. Thanks.
Don't we try to stay away from Intel GMA?
GMA3650 is really a third-party rebadge of a PowerVR SGX545 (see:
http://en.wikipedia.org/wiki/Intel_GMA#GMA_3600). AFAIK, there is no driver support in Linux and from my own testing in Windows it's very slow (slower than D525/GMA3150), won't play Netflix and you need to turn of Aero to even use it as a nettop.
(2013-08-29, 21:16)Dougie Fresh Wrote: [ -> ]GMA3650 is really a third-party rebadge of a PowerVR SGX545 (see: http://en.wikipedia.org/wiki/Intel_GMA#GMA_3600). AFAIK, there is no driver support in Linux and from my own testing in Windows it's very slow (slower than D525/GMA3150), won't play Netflix and you need to turn of Aero to even use it as a nettop.
Thanks for info. And advice..??
My apologies. I saw HDMI 1080p, atom D2550 and swear I saw ION in that spec. I would of searched GMA before saying it was good!
My revo 3700 is atom D525 and ION2. Which doesn't help lol.
Hmmm. Back to the drawing board then. Thought it was too good to be true.
Thanks though.
What's your budget? Requirements?
