2013-08-30, 07:34
This is a simple way to be able to access your HTPC using your favorite VNC client. It does not depend on any desktop environment or display manager.
1. sudo apt-get install x11vnc
2. Put the following command in /etc/rc.local, right before the "exit 0" line. Replace the "xbmc" user if you have to.
3. Restart your computer or run the above command as root.
su - xbmc -c "x11vnc -display WAIT:0 -forever -bg" > /dev/null 2>&1 &
