Since somebody else might have this problem, I thought about opening an extra thread for this.
I installed vdr and the xvdr plugin from aap's repository and xbmc / xvdr addon (also from aap's rep, xbmc-fernetmenta). I edited the channels.conf (with channels from channelpedia) but I'm always getting "Can't get device for channel".
This is from syslog:
EDIT: DO NOT POST LOGS TO THE FORUM!
Any ideas?
Additional Info: Only one of the tuners / cards is connected atm.
Hm, I can't get the streamdev plugin installed, apt-get install says package not found. Weird because it's in the aap ppa. Regaring to the fix: Priority is already set to 50.
The aap ppa description:
This ppa contains a VDR+XVDR based backend for XBMC. By default VDR is configured for watching digital TV from Eutelsat W4/W7 36E.
What kind of configuration does he talk about? I changed the channels.conf, but do I need to configure something else to watch Astra 19.2E?
I found the problem....diseqc.conf was set to Eutelsat. I replaced it with this 4 lines:
S19.2E 11700 V 9750 t v W15 [E0 10 38 F0] W15 A W15 t
S19.2E 99999 V 10600 t v W15 [E0 10 38 F1] W15 A W15 T
S19.2E 11700 H 9750 t V W15 [E0 10 38 F2] W15 A W15 t
S19.2E 99999 H 10600 t V W15 [E0 10 38 F3] W15 A W15 T
No idea about the Eutelsat config, I'm using it with cabletv so I dont't think it should stop you from watching. You could install the streamdev plugin with dpkg
https://launchpad.net/~aap/+archive/vdr/+build/4905718 download the server, which should be enough, install with sudo dpkg -i vdr-plugin-streamdev-server_0.6.0-522~d7652d8-ppa1~quantal_i386.deb
Edit: too late, good thing you found it, have fun with your tv
Well, tv worked for a second, now it's not working again. But I have to take care of some things, will be back on this problem in the evening. Thanks for your help!
