(2014-11-24, 07:00)McButton Wrote: [ -> ]Finally! I helped someone instead of asking 200 questions. Badge accepted.
And you now have your first Reputation Point
So I updated to the latest and greatest beta, after reinstalling my PC. Now, I have a weird thing where it no longer auto fills in sets. I have to do it all by hand. Any ideas?
(2014-11-24, 23:17)arcelas Wrote: [ -> ]So I updated to the latest and greatest beta, after reinstalling my PC. Now, I have a weird thing where it no longer auto fills in sets. I have to do it all by hand. Any ideas?
If you mean moviesets: there is an option in Settings -> Movies -> Scraper-Data -> Add movie automatically to Collections
DanCooper Thanks for the program.
For when new version
First let me say thanks for the work in keeping this alive great work I haven't read through all the threads but did try
to see if anyone is having the same issue as me I cant get it to create the folder/movie fanart or poster only seems
to want to create
Lucy (2014) Bluray-fanart.jpg and
I have modded the skin I use and it needs Folder
this is no big deal as I can just create it myself but if its an easy fix :-)
I have eden ticked with the options I want but cant see any errors thanks in advance :-)
(2014-11-25, 16:32)Ram2000 Wrote: [ -> ]First let me say thanks for the work in keeping this alive great work I haven't read through all the threads but did try
to want to create
The default Eden filename for posters is <filename>.
tbn, not jpg.
But you can add own filenames in expert tabs.
For movies inside separate movie folders add this in the poster field in "Single" tab:
Use the "Multiple" tab if you have saved all movies in one folder.
(2014-11-25, 10:42)DanCooper Wrote: [ -> ] (2014-11-24, 23:17)arcelas Wrote: [ -> ]So I updated to the latest and greatest beta, after reinstalling my PC. Now, I have a weird thing where it no longer auto fills in sets. I have to do it all by hand. Any ideas?
Thank you very much. Worked perfectly
New release 1.4.0.7 is online!
So I take it if I have always used used expert settings to name my banners "banner.jpg" I don't need to follow tutorial? Can I now just undo the expert setting and check all the artwork downloader buttons and be good?
(2014-11-27, 14:44)AnthonyJS02 Wrote: [ -> ]So I take it if I have always used used expert settings to name my banners "banner.jpg" I don't need to follow tutorial? Can I now just undo the expert setting and check all the artwork downloader buttons and be good?
Yes.
ArtworkDownloader default for movie banners is "banner.jpg".
Hello once again
I don't have my dev machine available, or I'd help solve this one... Using EMM 1.4.0.7x86 on Win 7 Pro x64
But on first run, when it asks for language, I click the drop-down box and select "English_us". It instantly comes back with an "Object reference not set to an instance of an object" message. Clicking OK on that message terminates the app.
There IS a Settings directory created though.
2nd run starts the program normally, albeit with defaults.
Created
ticket 165 at the tracker.
(2014-11-27, 18:19)Dekker500 Wrote: [ -> ]Hello once again
I don't have my dev machine available, or I'd help solve this one... Using Win 7 Pro x64
Created ticket 165 at the tracker.
i have the same error, but on a existing directory, with ember 1.4.0.6. After click on OK, ember starts normally...
(2014-11-25, 16:50)DanCooper Wrote: [ -> ]The default Eden filename for posters is <filename>.tbn, not jpg.
Thank you Dan that solved it please keep up the GREAT work :-)
(2014-11-27, 13:34)DanCooper Wrote: [ -> ]New release 1.4.0.7 is online!
Nice one mate.
Is it best to start fresh with this or can we use our old settings?
