(2015-10-10, 11:01)Cocotus Wrote: [ -> ]Can you check your videofile directly using MediaInfo? If you can scan your movie with the standalone tool and send the XML view to me or post here, that would be great. Link to Tool: http://mediaarea.net/en/MediaInfo
Will do I use that software all the time for checking media. Out at the moment but will get that to you
(2015-10-10, 16:43)meridius Wrote: [ -> ] (2015-10-10, 11:01)Cocotus Wrote: [ -> ]Can you check your videofile directly using MediaInfo? If you can scan your movie with the standalone tool and send the XML view to me or post here, that would be great. Link to Tool: http://mediaarea.net/en/MediaInfo
No, we use that in Ember to read the meta data from media files. But to proof why your file can not be detected you have to do this whit the standalone software and send us the meta information.
Any ETA on the new version??
(2015-10-10, 17:39)solamnic Wrote: [ -> ]Any ETA on the new version??
Pre-Release is out to a small group of (german) users for testing and debugging
(2015-10-10, 14:32)DanCooper Wrote: [ -> ] (2015-10-10, 14:25)cd492 Wrote: [ -> ] (2015-10-10, 13:10)DanCooper Wrote: [ -> ]And what is the problem?
Ember doesn't find this TV Show.
Hmmm, maybe the reason is that TVDB has listed this show only with German language.
Please try to change the tv show language to german with Context Menu => Language => German => Set and try to rescrape it.
Perfect that worked, thanks!
Hi, I have EMM 1.4.7.2 and am having problems scraping. I picked auto scrape for all items but it scrapes one movie every 15 mins or so. Can someone help?
(2015-10-10, 17:50)DanCooper Wrote: [ -> ] (2015-10-10, 17:39)solamnic Wrote: [ -> ]Any ETA on the new version??
cheers.... (need the new version due to the tv show bug
Thanks meridius! I formatted your post a bit, and put the whole xml stuff in code tag, hope you don't mind
The PCM information is there, so now I check why its not showing in Ember....
Quote:<track type="Audio">
<ID>2</ID>
<Format>PCM</Format>
<Codec_ID>00001000-0000-0100-8000-00AA00389B71</Codec_ID>
<Duration>2h 48mn</Duration>
<Bit_rate_mode>Constant</Bit_rate_mode>
<Bit_rate>4 608 Kbps</Bit_rate>
<Channel_s_>6 channels</Channel_s_>
<Channel_positions>Front: L C R, Side: L R, LFE</Channel_positions>
<Sampling_rate>48.0 KHz</Sampling_rate>
<Bit_depth>16 bits</Bit_depth>
<Stream_size>5.42 GiB (17%)</Stream_size>
<Title>LPCM 5.1</Title>
<Language>English</Language>
The CodecID seems strange to me.. I will try to find a video sample with PCM as audio to reproduce this but meanwhile can you try to map "00001000-0000-0100-8000-00AA00389B71" to "pcm" in Ember mapping editor and then rescan metadata to see if that helps?
(2015-10-11, 17:45)Cocotus Wrote: [ -> ]The CodecID seems strange to me.. I will try to find a video sample with PCM as audio to reproduce this but meanwhile can you try to map "00001000-0000-0100-8000-00AA00389B71" to "pcm" in Ember mapping editor and then rescan metadata to see if that helps?
that worked it picked it up as a pcm track
I have checked a few movies and many seem to use four types
"A_PCM/INT/LIT"
"A_PCM/INT/BIG"
"A_PCM/FLOAT/IEEE"
I have a lot of movies that use the top 2 formats
some more info on this
http://www.avsforum.com/forum/39-network...audio.html
Weird question. Is there some "clean library" function? I sometimes move movies between harddisks and EMM sees them twice (duplicates) in old and new location. I tried "reload movies"; but this did not solve the issue.
Any thoughts?
