Thank you!! I tried selecting a large chunk of my movies and running the command. The first time I did it, it worked. However, for the rest of the movies, if I select a couple of movies and run the command, it doesn't download any trailers.
To troubleshoot, I tried running the command on just one movie. It didn't work. Then I double clicked on the movie on EMM, went to the Trailers tab, and hit 'Scrape Trailers'. It found one trailer, I told it to download and it worked.
Why didn't it work when I ran the command by right-clicking the movie name and going to "(Re)scrape Selected Movies > Automatic (Force Best Match) > Trailer Only"?
2015-12-10 17:42:05.9551,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,317,TRACE,Starting MOVIE scrape,
2015-12-10 17:42:05.9551,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,317,TRACE,Start scraping: Capote (2005),
2015-12-10 17:42:06.0244,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,317,WARN,No generic modules defined <BeforeEdit_Movie>,
2015-12-10 17:42:07.4991,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeImage_Movie,317,TRACE,Scraping movie images using <TMDB_Image>,
2015-12-10 17:42:07.4991,ScraperModule.TMDB_Image,ScraperModule.TMDB_Image.Scraper,317,TRACE,Started scrape TMDB,
2015-12-10 17:42:07.7842,ScraperModule.TMDB_Image,ScraperModule.TMDB_Image.Scraper,317,TRACE,Finished TMDB Scraper,
2015-12-10 17:42:07.7882,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeTrailer_Movie,317,TRACE,Scraping movie trailers using <TMDB_Trailer>,
2015-12-10 17:42:07.7882,ScraperModule.TMDB_Trailer,ScraperModule.TMDB_Trailer.Scraper,317,TRACE,Started scrape,
2015-12-10 17:42:09.7501,ScraperModule.TMDB_Trailer,ScraperModule.TMDB_Trailer.Scraper,317,TRACE,Finished scrape,
2015-12-10 17:42:09.7501,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,317,WARN,[Capote] Avalaible trailers: 1,
2015-12-10 17:42:11.4719,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,317,WARN,No generic modules defined <ScraperMulti_Movie>,
2015-12-10 17:42:11.4738,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,317,WARN,No generic modules defined <OnNFOSave_Movie>,
2015-12-10 17:42:12.2580,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,317,WARN,No generic modules defined <Sync_Movie>,
2015-12-10 17:42:12.2580,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,317,TRACE,Ended scraping: Capote (2005),
2015-12-10 17:42:12.2580,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,317,TRACE,Ended MOVIE scrape,
Thanks for the help.
I think I got it! I enabled the other trailer sources, (Apple, HD-Trailers, etc.) and now they're downloading. I'll report back after I've let it download for a while.
