Installer routine nearly finished :-) I need volunteers for testing....
Will test when i get home
(2014-04-02, 13:37)redglory Wrote: [ -> ]Will test when i get home
Will send when i'm done ;-)
I'll give it a shot if you wanna shoot me a link!
Tester here ;o)
btw, I do have regular crash after 2 scrapes.
I do scrape in French and, once done, I do manually scrape the trailer (it's not working during initial scrape).
After 2 movies, the system hangs.
I do have Windows 7 Ultimate 64bits and using the 64bits version.
Great job!
I'm really overwhelmed by work and family affairs (in addition to my raid 5 failing on 2 disks
) so I'm a little offline...
(2014-04-03, 19:17)m.savazzi Wrote: [ -> ]Great job!
I'm really overwhelmed by work and family affairs (in addition to my raid 5 failing on 2 disks ) so I'm a little offline...
2 disks failing on RAID5 ?!
Damn !!! Pretty rare... and no luck.
(2014-04-03, 19:08)MoBO Wrote: [ -> ]Tester here ;o)
Exactly the same issue, even using the latest build installer @32bit and 64bit versions
(2014-04-04, 21:09)nick w Wrote: [ -> ] (2014-04-03, 19:08)MoBO Wrote: [ -> ]Tester here ;o)
Please upload your Settings.xml, AdvancedSettings.xml and logfiles. I hope i can find an issue.
