(2013-09-02, 23:07)T-bird_se Wrote: [ -> ]What ever order the scrapers is setup in, all info scraping is from the last one
can you help me understand how you detected this? which movie were you using?
can you provide me examples?
I created a new version with some fixes for the options. Can you test it?
Hi Massimo,
where is the new version ?
Forgotten the upload ?
(2013-09-07, 23:12)m.savazzi Wrote: [ -> ] (2013-09-02, 23:07)T-bird_se Wrote: [ -> ]What ever order the scrapers is setup in, all info scraping is from the last one
It's easy to see for me.
I want all info except ratings from TMDB, and I want it in Swedish
When TMDB is in last order I get the plot in Swedish but also votes
If I set IMDB last I get plots in English and the correct votes
It's the same for all movies but an example for the votes of Avatar (2009)
TMDB=5127
IMDB=almost 600000
As already mentioned, new download is missing
(2013-09-08, 11:56)videojones Wrote: [ -> ]Hi Massimo,
ops
switched off the pc before sync was finished!
sorry
(2013-09-08, 12:40)T-bird_se Wrote: [ -> ] (2013-09-07, 23:12)m.savazzi Wrote: [ -> ] (2013-09-02, 23:07)T-bird_se Wrote: [ -> ]What ever order the scrapers is setup in, all info scraping is from the last one
TMDB=5127
IMDB=almost 600000
can you show me your configuration?
for me works fine now.
Found an error in the settings page for TVdb (shows): a lot of settings are in the global page and should be moved under the scraper. I've started removing the duplicated API field but even the others should be moved.
Only global parameters (like the locks) should be there!
"Lock Outline" option do not work when I use TMDB scrapper and "Use plot for outline of outline is empty" option.
When I scrape for first time and outline do not exist (but there is plot) than Ember creates outline from plot properly. But when I will do scrape on same item for second time Ember deletes already created outline and leave it empty.
Hello, did this feature make it into this version of the beta?
-auto-scraping with "Skip Movie If No Exact Title Found"
Thank you
Found a nasty bug
If you hit reload on an TV-Show all seasons and episodes disappears, only the show name left, doesn't matter if the show is scraped or not
Checking Embers DB and in TVSeason table only season 999 left and that seems to be some sort of endmarker
In TVEps table the missing episodes exist but episode and season number is -999
(2013-09-15, 00:31)T-bird_se Wrote: [ -> ]Found a nasty bug
will check it.
Sometimes happened to me too but, after a refresh it was fine
Fixed several bugs.
the fact all info is downloaded
wrong place for TVDB language options
info and images saved BEFORE movie edit window is shown
please test
(2013-09-29, 18:49)m.savazzi Wrote: [ -> ]info and images saved BEFORE movie edit window is shown
Could you explain that a bit closer?
You have to save the files in the temporary folder first, and with the confirmation of the edit-window, the files will be saved locally.
