2014-05-09, 19:13
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217
2014-05-09, 21:21
(2014-05-09, 17:45)DanCooper Wrote: [ -> ](2014-05-09, 16:22)Pr.Sinister Wrote: [ -> ]#1. Trailer downloading is not working for me. I only tried it in the Custom Scraper and with Change Movie
#1 Hmm, no idea. But the trailer download windows does not start automatically like in 1.3.x, you need to click the green button in edit movie window (i will fix that someday). But auto scraping works normally for me.
Ok i have tried everything and it simply isn't working. It scrapes the trailer to the nfo but doesn't download it. Even if i press the + and choose the one i want!
Also, i have a problem with some settings not being saved. I get the following errors :
time,logger,callsite,threadid,level,message
2014-05-09 14:09:45.1081,Ember_Media_Manager.dlgSettings,EmberAPI.ErrorLogger.Error,1,ERROR,"Object reference not set to an instance of an object.
at Ember_Media_Manager.dlgSettings.SaveSettings(Boolean isApply)"
2014-05-09 14:10:04.0742,Ember_Media_Manager.dlgSettings,EmberAPI.ErrorLogger.Error,1,ERROR,"Object reference not set to an instance of an object.
I have started from scratch and reinstalled a clean version of Ember 1.4.0.0 x86 from May 9th and it still isn't working. When I click the green + and choose the trailer, there is no progress bar that it is downloading and it immediately says Local Trailer available but it's not. Then i go to the Ember Temp folder and i see a file called trailer.mp4 and it is the right trailer. Somehow it is not moved to the movie folder.
Also, everytime i exit Ember and reopen it, i go back to settings, the fanart.tv, imdb and impa scrapers are disabled again even though i enabled them before. Any changes i make to those settings are not saved.
That means to be able to scrape from fanart.tv, i have to go in, enable the scraper and scrape right there. If i exit and go back in it won't scrape from fanart.tv
One last thing, running in the command-line -newauto -all doesn't work for me. It only scrapes the basics and nothing from fanart.tv. I assume it's because it doesn't keep the settings...
2014-05-09, 21:34
I just realized that a clean install of Ember 1.4 Beta does not contain or create advancedsettings.xml
Could that be the problem with scraper stuff not being saved?
2014-05-09, 21:38
(2014-05-09, 21:21)Pr.Sinister Wrote: [ -> ]Ok i have tried everything and it simply isn't working. It scrapes the trailer to the nfo but doesn't download it. Even if i press the + and choose the one i want!
Code:time,logger,callsite,threadid,level,message
Settings issues:
go to Edit -> Settings -> TV Shows -> General and click the "Fetch Avaible Languages" button in "Language Options" groupbox. This will also refresh the languages in TVDB scraper after you start again the settings dialog.
Then also Command Line should work.
Trailer:
I have used a workaround in order to prevent that the trailer is already saved before the window is confirmed (old Ember 1.3.x style). The label "Local Trailer Found" is wrong, I know. The trailer will only be saved when the edit movie window is closed (currently without a bar). Therefore, the closure also takes so long. During the closing the trailers and ActorThumbs will be downloaded and stored.
Please try again.
(2014-05-09, 21:34)Pr.Sinister Wrote: [ -> ]I just realized that a clean install of Ember 1.4 Beta does not contain or create advancedsettings.xml
I think AdvancedSettings will only created after first open and confirm settings dialog. Maybe a bad solution
I will check if I can solve that...
2014-05-09, 22:48
(2014-05-09, 21:38)DanCooper Wrote: [ -> ]Trailer:
Please try again.
I tried again with the trailer and it does take a long time to close but it doesn't copy it to the movie's folder. It also doesn't work in Auto Scrape, Custom Scrape or Change Movie
Also, in Auto Scrape, Extrathumbs and Extrafanarts are not generated or saved. When editing the movie, there is no way to force it either.
There is missing a setting under Fanart where you could say Save Fanarts as Extrathumbs... It was there in 1.3.x now it's gone.
Dan, do you have a clean install of Ember to try this? Because at the very least, starting from scratch should work like it does for you but yet it doesn't.
BTW: advancedsettings.xml got created after i downloaded the languages for TV Shows (Which i don't use)
2014-05-10, 00:06
(2014-05-09, 22:48)Pr.Sinister Wrote: [ -> ]I tried again with the trailer and it does take a long time to close but it doesn't copy it to the movie's folder. It also doesn't work in Auto Scrape, Custom Scrape or Change Movie
Trailer:
I will check that tomorrow, works for me.
Auto-Scrape:
Set the "Limit" in Images -> Extrathumbs/Extrafanarts to "0".
Edit movie and Extrafanarts/Extrathumbs:
Go to tab Fanart and click on scrape. You need to (re)select one image as fanart (i will change that later) and check more images for Extrafanart/Extrathumbs.
AdvancedSettings:
Has to now work for all. I test it tomorrow again with a new installation.
2014-05-10, 15:15
After reloading all movies, all the images are shown however the banner column doesnt show a tick even though theres a banner in the folder named as "banner.jpg"
2014-05-10, 15:43
(2014-05-10, 15:15)elnino-1900 Wrote: [ -> ]After reloading all movies, all the images are shown however the banner column doesnt show a tick even though theres a banner in the folder named as "banner.jpg"
Banner you have to go to the ember file name expert settings. Unstick from frodo go to expert tab and click banner and type banner.jpg there. Had to do that on last release.
2014-05-10, 16:01
(2014-05-10, 15:43)AnthonyJS02 Wrote: [ -> ](2014-05-10, 15:15)elnino-1900 Wrote: [ -> ]After reloading all movies, all the images are shown however the banner column doesnt show a tick even though theres a banner in the folder named as "banner.jpg"
Yes, that's right. I have named banner for Frodo as <moviename>-banner.jpg (the same as in tv shows), but ArtworkDownloader use "banner.jpg".
I will wait for the next AD release before i do change this. I think he will add new settings for AD.
In my opinion, the best way to get unique filenames is:
That would be the cleanest solution. So the whole would also work with several films in the same directory.
2014-05-10, 16:37
Used the above instructions but still kept giving me an error of "object reference not set". So I uninstalled ember beta and did a fresh install but adding banner.jpg to the settings page that appears when you first setup ember and now everything appears..
2014-05-10, 17:12
DanCooper, first off all, congratulations for the brilliant work!
Question: It's possible change the base to search themes(OST) to the movies and series? Goear find only 5% off my all bibliotec (1450 movies...)
Sorry for my poor english.
Tks so much!
Tks so much!
2014-05-11, 15:06
Dan or anyone ! is the commandprompt (newautoall) working with this beta ? if i recall updating Tv Shows was also being included in this ? is that working at the moment?
Have installed this with my new fresh install on Windows8.1, for use with Xbmc Gotham & Aeon Nox 4.9 Gotham, everything else is working brilliantly just am unable to automate the process.
I am trying to run ember as a post processor after couchpotato OR as an scheduled task . I was previously able to do that with the 1.3x just am not able to get it working with 1.4x
2014-05-11, 15:51
(2014-05-11, 15:06)shaktoo Wrote: [ -> ]Dan or anyone ! is the commandprompt (newautoall) working with this beta ? if i recall updating Tv Shows was also being included in this ? is that working at the moment?
Tv shows are not implemented (i don't know why not). But i will add it in next release (tv show update is working like click "Update Library" in main menu, no autoscraping, only recognize new episodes and save episode poster and nfo if the tv show is already scraped and the TVDB.zip is available in temp folder).
-newauto -all
(2014-05-10, 17:12)Soujirou Seta Wrote: [ -> ]DanCooper, first off all, congratulations for the brilliant work!
Tks so much!
What do you mean exactly?
I'll revise the Theme scraper once the new TVTunes addon is released. After that I will take over the scraper and settings 1:1.
2014-05-11, 16:05
Thanks for the reply. good to know TV Show update will be integrated. What is remaining is the watch folder & hence complete automation as requested previously and already on the books .
Dan would you mind sharing the working emm-scraper with me so I can Give it a try.. I have not been able to get it working on my system ..Thanks
2014-05-11, 16:19
(2014-05-11, 16:05)shaktoo Wrote: [ -> ]Thanks for the reply. good to know TV Show update will be integrated. What is remaining is the watch folder & hence complete automation as requested previously and already on the books .
That does not make much sense at the moment. I program the movie sets completely new and the present state is not yet executable.
