(2013-11-15, 08:55)BeesKid Wrote: [ -> ]hi there, i just started using XBMC 2 day ago... i like this skin very much n wonder if anyone can show me step by step how to add movies to a custom menu (example ANIME)? i know how to add custom menu but i have no idea how to add movie.... plz help n i do have movie in my movies library.
As far as I know: you need to make a playlist that filters out your anime stuff, use "C" on keyboard to bring up context menu; add that list to favourites; assign that favourite item to an empty slot on main menu in skin settings.
(2013-11-15, 15:54)pecinko Wrote: [ -> ] (2013-11-15, 08:55)BeesKid Wrote: [ -> ]hi there, i just started using XBMC 2 day ago... i like this skin very much n wonder if anyone can show me step by step how to add movies to a custom menu (example ANIME)? i know how to add custom menu but i have no idea how to add movie.... plz help n i do have movie in my movies library.
thank you.... another question. anyone know how to use Ember Media Manager?
Hello Guys,
I'm new to this Skin. How is it possible to only show 1 Row in the movie menu. Like:
http://i.imgur.com/X7CQ50Z.jpg
Right now i have 2 Rows.
when browsing movies pressing info does nothing, it's normal? when browsing tvshows i can see the show info.
(2013-11-17, 21:44)francovilar Wrote: [ -> ]when browsing movies pressing info does nothing, it's normal? when browsing tvshows i can see the show info.
Are your movies scanned into the library?
Do you have Universal Movie Scraper addon enabled?
artrafael and MilhouseVH : yes to both
I tryed in another system (I'm using Mysql database) and it's working fine. I will delete the folder and clone again. Thank you.
Nobody has a solution for the Question about the "1Row view"? Please
(2013-11-19, 09:33)racon Wrote: [ -> ]Nobody has a solution for the Question about the "1Row view"? Please
Settings > Home Shelf > Configure Shelf Items > Recommended > disable
Repeat for Random Items
@artrafael: Problem solved. Thank you :-)
(2013-10-22, 19:41)pecinko Wrote: [ -> ] (2013-10-22, 17:05)danmedhurst Wrote: [ -> ]@pecinko
Would you ever consider enabling the option for "Movies always go to files view" like it used to be in the old days of confluence? I'm always having to put this back in (as you can see above) in the includes.xml when you update the skin...
I'll add an option for - "Always go to files" or "Always go to playlists"
Did you ever get round to adding this?
many thanks
Dan
(2013-11-19, 22:00)pecinko Wrote: [ -> ] (2013-11-19, 17:02)danmedhurst Wrote: [ -> ] (2013-10-22, 19:41)pecinko Wrote: [ -> ]I'll add an option for - "Always go to files" or "Always go to playlists"
many thanks
Dan
No, not just yet.
Ok, thanks. I'll hold off updating for now
So it is the general consensus that the vertical menu blocking most of the background image is a good thing
There's no reason for it and it definitely takes away from an otherwise wonderful skin......any options to correct this obvious mistake?
(2013-11-19, 23:04)danmedhurst Wrote: [ -> ]Ok, thanks. I'll hold off updating for now
Added on git.
- files
- playlists
- library filters/nodes
- all movies (default)
(2013-11-20, 05:56)Scott00007 Wrote: [ -> ]So it is the general consensus that the vertical menu blocking most of the background image is a good thing?
To be frank I don't really care about background art on home screen. Rather, I like to have my media available at hand so I don't need to browse for it. When I browse the library, there seems to be plenty of background art.
I guess I probably have a bug
That said I have lighten vertical home a bit - maybe you will find it a bit more attractive.
