2013-09-03, 11:21
Pages: 1 2
2013-09-03, 11:29
not atm
2013-09-03, 11:31
nope, there isn't.
xbmc doesn't store any 3D info in the db, so it's not available to skinners.
only during playback you can detect if a movie is 3D:
boolean condition: VideoPlayer.IsStereoscopic
infolabel: VideoPlayer.StereoscopicMode
for listitems, the only way to do it is using SubString(ListItem.FileNameAndPath, 3D) i think.
2013-09-03, 11:38
that should probably be:
to also catch filenames with 3D in them
SubString(ListItem.FileNameAndPath,3D)
2013-09-03, 11:45
i stand corrected
2013-09-03, 12:02
It would be nice to have ListItem support you don't have to keep hammering all labels with SubStrings.
I assume that we are able to recognise it during video info extraction process?
2013-09-03, 23:11
I have no idea how the listItem stuff works, but there is 3D related info stored along with the video in the DB (the flag you can set in video settings OSD). Once I have some time again I'll see if I can do the necessary changes to get 3D flags if it's not working with mentioned setting. I also have JSON/builtins support on my radar, so that f.e. remotes can change the stereo modes etc
2013-09-04, 12:31
(2013-09-03, 23:11)da-anda Wrote: [ -> ]I have no idea how the listItem stuff works, but there is 3D related info stored along with the video in the DB (the flag you can set in video settings OSD). Once I have some time again I'll see if I can do the necessary changes to get 3D flags if it's not working with mentioned setting. I also have JSON/builtins support on my radar, so that f.e. remotes can change the stereo modes etc
Great. I suppose it could be done in the same way like ListItem.VideoCodec or ListItem.AudioChannels are implemented.
2013-09-05, 11:48
My prayers where heard ;-)
Good luck pecinko and I hope da-anda has some time soon because I think/hope I'm not the only one waiting for 3D labels/falgs without catching filenames with '3D' in it.
Thanks a lot for your effort and enthusiasm bringing XBMC forward.
Kindest regards
XBMC4me
Kindest regards
XBMC4me
2013-09-20, 11:21
fyi I started working on it, but I have absolutely no idea how this stuff works, so it's basically try and error atm and everything I did so far is completely untested (not even compile tested due to lack of build-env atm). If one dares to have a look, here is my repo/branch https://github.com/da-anda/xbmc/tree/3d-streamdetails
2013-09-21, 10:50
(2013-09-20, 11:21)da-anda Wrote: [ -> ]fyi I started working on it, but I have absolutely no idea how this stuff works, so it's basically try and error atm and everything I did so far is completely untested (not even compile tested due to lack of build-env atm). If one dares to have a look, here is my repo/branch https://github.com/da-anda/xbmc/tree/3d-streamdetails
Hopefully somebody would jump in - I don't have build environment either, nor do I have any 3D content in my library...
2013-09-27, 14:57
I updated my branch and it seems to partly work already (struggling a bit with the boolean ListItem.IsStereoscopic and the skin changes).
I don't handle the case atm where ffmpeg doesn't detect the stereomode and one has to set it manually in OSD video settings. I'm actually not sure how to handle this nicely, drop one in favor of the other, merge them just for the InfoLabels, update streamdetails if video settings change etc. Will talk with elupus about it.
2013-10-09, 15:01
headsup: it's basically working, but it's more difficult than expected, given that we can't detect the stereoscopic mode in the videostream details for all movies. Thus I have to somehow combine it with the detection by filename and that's not as easy as it seems. I mean I have it working, but I've been told it's probably not the right spot to aggregate the info (infomanager where all other ListItem info is processed) and it should be done by some background process or whatever. We'll talk about this at devcon if time allows.
2013-10-10, 10:38
(2013-10-09, 15:01)da-anda Wrote: [ -> ]headsup: it's basically working, but it's more difficult than expected, given that we can't detect the stereoscopic mode in the videostream details for all movies. Thus I have to somehow combine it with the detection by filename and that's not as easy as it seems. I mean I have it working, but I've been told it's probably not the right spot to aggregate the info (infomanager where all other ListItem info is processed) and it should be done by some background process or whatever. We'll talk about this at devcon if time allows.
2013-11-06, 23:20
good news, my PR been merged couple mins ago. see http://forum.xbmc.org/showthread.php?tid...pid1544614
Pages: 1 2
