2013-09-03, 12:26
Now that I have the iplayer working again (after a problem where it would not close a stream I had paused once) , I am having a new problem.
I think what is happening is that only the highest resolution is being chosen, and my connection presumably can't support that.
When I watch iplayer through a browser, it works fine, though it usually starts, pauses for a second or two then continues flaweleslyy - I believe that is when a lower stream rate is selected.
I'm guessing there is something in the xbmc settings somewhere that I can set to allow it to automatically choose the best resolution?
Thanks,
Thanks,
