2018-10-15, 13:24
Pages: 1 2
2018-11-05, 08:26
Sorry man, never saw this post... Updated link below
https://www.dropbox.com/s/61xqeqshjhqlz9...0.zip?dl=0
2020-03-30, 16:08
Again offline.. would you upload it again?
2020-03-31, 12:33
I've stopped using dropbox and have uploaded it to github - first post has been updated.
2020-03-31, 14:25
Thank you! Actually i missed a thing:
I am using libreelec for KODI on a multi OS system. But the grub commands are not supported by libreelec - so it will not work
2020-03-31, 21:46
I had it working on openelec with grub. Here is the link, though do note it is very old and I don't use openelec/libreelec anymore so I can't provide much support to get it working
https://github.com/teeedubb/teeedubb-xbm...p?raw=true
2020-04-01, 08:18
Thank you i will take a look and try. The file is access restricted, can you publish it?
2020-04-01, 10:23
Sorry about that, link has been updated
2020-04-02, 11:56
Thank you, worked for me.
I had to adjust some certain stuff including to recompile as some directories are different to openelec. It seems i am very close but one thing fails, I can`t load a certain lib:
/storage/.kodi/addons/script.reboot2oos-oe/bin/grub-editenv: error while loading shared libraries: libdevmapper.so.1.02.1: cannot open shared object file: No such file or directory
I took the file from the compiling os but cant add it as the /lib folder is write protected on LE. I added a custom dir to the $LD_LIBRARY_PATH with the file inside but didn`t work either.
I also tried to add a custom lib dir to the compilation configuration:
./configure --libdir=/storage/.kodi/addons/script.reboot2oos-oe/lib --exec-prefix=/storage/.kodi/addons/script.reboot2oos-oe --prefix=/storage/.kodi/addons/script.reboot2oos-oe --sbindir=/storage/.kodi/addons/script.reboot2oos-oe/bin --disable-grub-mkfont
But also doesn`t work. Do you mabe have further ideas?
UPDATE: Made it work with "export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/storage/.kodi/addons/script.reboot2oos-oe/bin/lib" and execute from cli. Still looking for a way to add a custom lib path to the build of grub...
2020-04-06, 13:50
Everything now working fine. Thank you for the great addon!
I uploaded the addon configured for LibreELEC to github (script.reboot2oos-le). I hope this is ok for you @teeedubb otherwise let me know and i will remove it from there.
Pages: 1 2
