I can't find an answer for this. But when I play anything that is 720p or 1080p mkvs they play in like triple speed and pausing and settings won't change it... It happened eversince I upgraded to Gotham....
Do u have any thing clicked in ur xbmc settings such as audio/ tv sync? I ran into this when i was syncing audio and the tv... Might check into those settings...
Check your audio settings, in particular make sure you've the correct speaker configuration for your connection type, SPDIF is 2.0 and HDMI is 5.1 or 7.1.
Thanks all. The update changed my audio settings and there was a lot to choose from.... I kept clicking through until one worked. SO now I have surround with DD and DTS and 1080p with DXVA (Finally again)!
Solved
