Hi
I have accidentally hidden the settings option in the main menu on the home screen. Is there a shortcut key or a way of going into settings so I can unhide it?
Which skin are you using and which version of XBMC?
Xbmc 12.0 and aeon nox skin
press "s" and you can enter settings
Pressing s brings up a list of movies, tv, music ect. No settings. I've tried to change one of these to settings but its not in the config list either
(2013-09-05, 13:05)Litewait Wrote: [ -> ]Pressing s brings up a list of movies, tv, music ect. No settings. I've tried to change one of these to settings but its not in the config list either
if i hit "s" in home screen i get the menu to shutdown or go to settings
sorted.
i worked out how to add settings in the "s" menu
(2013-09-05, 15:32)Litewait Wrote: [ -> ]sorted.
How did you do it?
