Hi, I have the setting switched in setting to play the next video automatically. In plexbmc (for example) it works and does play the next video but in some plugins(youtube channels for example) it doesnt. Is there something I can change to get this to work or would the plugin need something changed?
I don't believe there is anything user-side that can be changed. It has to be supported in the add-on. Some add-ons can pass a URL/path to XBMC that allow the videos to be added to a normal XBMC playlist, which is how XBMC does the "play next automatically" feature. I believe it's the same reason why only some add-on content will work with the Favorites feature, too.
I suppose I should just contact the plugins authors for the ones im wishing this worked on. Thanks for the response!
