Full Version: Intel CE4100/Sodaville Development Board(HTPC/BOXEE/XBMC/SDK/PDK/opensource/hardware
I have several Intel_CE4100 development boards which developed based on intel CE4100,it has rich hardware interface and software resources, provides a very good development platform for the majority of embedded enthusiast, intel platform lovers, HTPC/XBMC/BOXEE or other open source software enthusiasts .
If you really need it or them,Please contact me.
Email:[email protected]
Intel_CE4100 development board specifications
Product Name Intel_CE4100 Devolopment Board
Power Source DC12V (3A)
OS Linux(intel PDK21.0)
Hardware CPU:Intel Atom processor CE4100
Clock:1.2GHZ
Momery:8 x 1GBit DDR3 SDRAM
Hard disk:8G ssd
Wireless Lan:support 802.11b/g/n wireless protocol
MCU:Microchip pic24
Standby power consumption:0.5W
Video Output HDMI,YPBBR
Audio Output L/R stereo, optical , coaxial
Interface USB, HDMI,YPBBR,optical,LAN,coaxial,mic,ESATA
Video Format MPEG4 AVI、MP4/H.264、DIVX4,DIVX5,XVID
MPEG1/2 MPG、MPE、VOB、DAT、TRP、TS
Windows Media Video Windows Media Video 7/8 (WMV1/2)
Windows Media Video 9 (WMV3) (using x86 DLL)
RealVideo -RealVideo 1.0, 2.0 (G2)
-RealVideo 3.0 (RP8), 4.0 (RP9) (using Real libraries)
Intel Indeo -Intel Indeo3 (3.1, 3.2)
-Intel Indeo 4.1 and 5.0 (using x86 DLL or XAnim codecs)
Other -Sorenson v1/v3 (SVQ1/SVQ3), Cinepak, RPZA and other QuickTime codecs
-DV video
-VIVO 1.0, 2.0, I263 and other H.263(+) variants (using x86 DLL)
-MJPEG, AVID, VCR2, ASV2 and other hardware formats
- FLI/FLC
- HuffYUV
-various old simple RLE-like formats
Picture Format BMP、JPG、JPE、PNG、GIF、TIF/TIFF、TGA、PCX、ICO、
Audio Format QuickTime Qclp, Q-Design QDMC/QDM2, MACE
3/6 (using QT libraries), ALAC
RealAudio RealAudio: DNET and older codecs
RealAudio: COOK, SIPRO, ATRAC3 (using Real libraries)
MP3 MPEG layer 1, 2, and 3 (MP3) audio
WMA -WMA (DivX Audio) v1, v2
-WMA 9 (WMAv3), Voxware audio, ACELP.net etc (using x86 DLLs)
AAC M4A、AAC/DTS
Other -Ogg Vorbis audio
-VIVO audio (g723, Vivo Siren) (using x86 DLL)
-alaw/ulaw, (ms)gsm, pcm, *adpcm and other simple old audio formats
Support external USB、SATA、WIFI
Support external mouse and keyboard
SDK specifications
SDK name Pdk21.0
Display driver(GDL) Intel® Media Processor CE 4100 GDL 3.0 API Specification
EGL, OpenGL* ES, and OpenVG* A new OpenGL ES 2.0 sample is available. This sample shows how to use video as a texture with a color conversion shader program. See the Graphics User’s Guide for details.
DirectFB* Intel® Media Processor CE 4100 DirectFB Users Guide
Intel® Media Processor CE 4100 DirectFB Programming Guide
•Added DirectFB USB keyboard and mouse input provider support. There is no support for
virtual terminal switching. The necessary device nodes are automatically created via a
script during boot and during hot-plug of these USB devices.
• Many defects related to multi-threaded DirectFB API usage were fixed. These fixes
include:
• pthreads multiple-reader-single-writer (MRSW) lock usage in which the writer thread would not wake up (resolved by implementing a custom MRSW lock for the drivers to use).
• Surface destruction race condition resulting in GDL surface unmapping failures.
• Display layer and mixer configuration race condition causing a display layer to sometimes not become enabled/visible.
• Subsurface destruction and flipping related deadlock.
• Surface destruction deadlock scenario involving DirectFB multi-app usage model.
• Updated the default directfbrc configuration file so that it no longer disables cursor usage.
Streaming Media Drivers • TS_out:
• Buffer monitor
• Frame Advance:
• Client ID “tags” through the video sub-system pipeline
•LBR Decoder
•MxN mixer
• Metadata Enabled Mixer
• Bass Management (Low Pass Filters)
• Core Message Management
• AC3 in MPEG2 stream System B format:
• TS playback over IP network:
• Server Side Trick Mode
• Simultaneous audio and karaoke support:
• Message information base:
• Field Polarity:
• DPE control and configuration options:
• Demux indexing for MPEG-2 streams:
• Video Decoder support for stream statistics:
Platform and Toolchain CEFDK
REDBOOT
toolchain
Advanced Access Content System • SEC AACS Driver
• AACS software framework library
• Intel signed AACS firmware module
• AACS Initialization tool
• AACS Utility - Key Provisioning
Xpsm Intel media player
Quick Bootable TargetFS Images In previous releases, target FS images were built as part of an entire SDK build. This process takes about 15-20 minutes. In this release the TargetFS component has added a new script, quick_create.sh, which can produce bootable TargetFS images in as little as 20-30 seconds. It does this by using the binaries provided in component target packages (the
target/ subdirectory of each component directory), and the TargetFS build system.
Open Source Components • GCC compiler version 4.1.1
• glibc version 2.7 (packaged with gcc 4.1.2)
• GDB version 6.8
• RedBoot* boot loader
• Linux* kernel 2.6.23/28
• BusyBox Environment 1.10.2
• GStreamer 0.10.17
• patch 2.5.4
• Bison 1.875
• m4 1.4..9
• autoconf 2.59
• automake 1.9.6
• freeType 2.1.10
• udev 120
• libusb 0.1.12
• libmtp 0.2.6
• ALSA (Advanced Linux Sound Architecture)
• ncurses 5.5
• DirectFB* 1.0.1 with changes for the Intel® Media •Processor CE 4100, and Intel® Media
•Processor CE 4100 specific drivers
• DirectFB 1.0.0 examples with changes for the Intel® •Media Processor CE 4100
• SGX graphics kernel module
• UDF patch 2.5
•Mplayer
•XBMC
•BOXEE
Giveaway
Development board preloads transplanted BOXEE system(not dlink BOXEE box), we provide you gift STB shell, infrared remote control, HDMI cable and power adapter to provide you with a complete STB solution, you can also transplant other open source software such as XBMC to create your own STB products according to your own preferences.
Sounds like an amazing tool to develop XBMC on Boxee Box. Would contact quarnster, who's currently leading the development of XBMC for Boxee Box or post on this thread http://forum.xbmc.org/showthread.php?tid=171959 .
thank ladude626 a lot!!!
I have send the post to my friends.They may be interesting in it, their company wants to find some kind of boards to test.
I want to make a HTPC device, Can you give me some pictures about the board?
