Hello to everyone.
Mine main issue is that I can't install the add-on. It's show percentage but it is 0% and right after it resetting the page and addon not installed.
I am using openlec on raspbery and I really nee cloud service for installing zip reposittorys.
Thanks for any help.
Hello,
I'm trying to sync the root folder of Dropbox in my Raspberry Pi (raspbmc) in a external hard drive. It doesn't sync and I get the following error in the kodi log:
16:36:12 T:2888266816 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.EOFError'>
Error Contents:
File "/home/pi/.kodi/addons/plugin.dbmc/sync_dropbox.py", line 32, in <module>
sync.run()
File "/home/pi/.kodi/addons/plugin.dbmc/resources/lib/sync/dropboxsync.py", line 51, in run
self.update_accounts()
File "/home/pi/.kodi/addons/plugin.dbmc/resources/lib/sync/dropboxsync.py", line 130, in update_accounts
account.init()
File "/home/pi/.kodi/addons/plugin.dbmc/resources/lib/sync/syncaccount.py", line 65, in init
self._get_settings()
File "/home/pi/.kodi/addons/plugin.dbmc/resources/lib/sync/syncaccount.py", line 209, in _get_settings
self._setupSyncRoot()
File "/home/pi/.kodi/addons/plugin.dbmc/resources/lib/sync/syncaccount.py", line 257, in _setupSyncRoot
clientCursor = self.getClientCursor()
File "/home/pi/.kodi/addons/plugin.dbmc/resources/lib/sync/syncaccount.py", line 279, in getClientCursor
cursor, data = self.getSyncData()
File "/home/pi/.kodi/addons/plugin.dbmc/resources/lib/sync/syncaccount.py", line 303, in getSyncData
cursor, data = pickle.load(f)
File "/usr/lib/python2.7/pickle.py", line 1378, in load
return Unpickler(file).load()
File "/usr/lib/python2.7/pickle.py", line 858, in load
dispatch[key](self)
File "/usr/lib/python2.7/pickle.py", line 880, in load_eof
raise EOFError
EOFError
I'm using the lastest version of dbmc, 0.9.3.
Do you know why is this happening?
Best regards,
(full log:
http://pastebin.com/APHtH6KG )
I just started Dbmc yesterday and still all I see when I select my account is the folders for the picture files I have in Dropbox. I do see dates when I go to view images downloaded from my phone file, but when I select any of these nothing appears. When I select on of the files I get all of the .mov items in that file, but none will play. Is there anything else I need to do/
I'm trying to add the Dropbox plugin but after entering all the codes I get an authorisation failed, can anyone help me please?
HI all!
I try to run Dbmc on Android 4.4.2 Kodi 15.1, Raspberry B and Raspberry 2, After adding the account, i get on all three a Error Messages if i try to start Dbmc.
I get a pop-up "Dbmc (Dropbox add-on) error, check the log for more information".
Also i can't see the account.
is there anny known bug?
I solved it myself :-)
Log reading helps!
The reason was the character "ß" in my account Name! I changed it into "ss" an did the account adding procedure again -> it works!
Hello everyone,
I'm using synchronization to sync a folder in my device but...
when it is synchronize?
some times in the first load of kodi and sometimes it takes days...
is there sync now or something?
I'm getting an error on RPI2 on OE 6 as well. Are you guys on Pi using OE? I'm not sure if its a Python issue in OE you know as I had errors from other addons using python too. Mine is during sync which works to start with then breaks later. Weirdly I can browse the remote folder if I go into dbmc its just the sync that isnt working.
01:00:42 42.457886 T:1429365824 ERROR: GetDirectory - Error getting
01:00:46 46.528252 T:1446143040 ERROR: Exception in thread Thread-2:
File "/home/stephan/projects/openelec-6.0/build.OpenELEC-RPi2.arm-6.0.0/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/sync/syncthread.py", line 43, in run
self._getRemoteChanges()
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/sync/syncthread.py", line 61, in _getRemoteChanges
items, clientCursor, reset, hasMore = self._sync_account._client.getRemoteChanges(clientCursor)
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/dropboxclient.py", line 48, in wrapper
return f(self, *args, **keywords)
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/dropboxclient.py", line 345, in getRemoteChanges
response = self.DropboxAPI.delta(cursor)
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/dropbox/client.py", line 468, in delta
return self.rest_client.POST(url, params, headers)
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/dropbox/rest.py", line 262, in POST
return cls.IMPL.POST(*n, **kw)
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/dropbox/rest.py", line 209, in POST
post_params=params, headers=headers, raw_response=raw_response)
File "/storage/.kodi/addons/plugin.dbmc/resources/lib/dropbox/rest.py", line 179, in request
raise RESTSocketError(host, e)
RESTSocketError: Error connecting to "api.dropbox.com": [Errno 1] _ssl.c:504: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
[/php]
23:06:18 T:10056 NOTICE: plugin.dbmc: Enabled synchronization for AF TV
23:06:19 T:13084 NOTICE: plugin.dbmc: Synchronizing number of items: 0/1 (AF TV)
23:06:19 T:13084 ERROR: XFILE::CDirectory::Create - Error creating special:/masterprofile
23:06:19 T:13084 ERROR: XFILE::CDirectory::Create - Error creating special:/masterprofile/addon_data
23:06:19 T:13084 ERROR: XFILE::CDirectory::Create - Error creating special:/masterprofile/addon_data/plugin.video.salts
23:06:19 T:13084 ERROR: plugin.dbmc: Failed saving file special:\masterprofile\addon_data\plugin.video.salts\settings.xml. Error: [Errno 22] invalid mode ('wb') or filename: u'special:\\masterprofile\\addon_data\\plugin.video.salts\\settings.xml'
23:06:19 T:13084 ERROR: plugin.dbmc: Exception occurred for file special:\masterprofile\addon_data\plugin.video.salts\settings.xml
23:06:19 T:13084 ERROR: plugin.dbmc: Traceback (most recent call last):
File "C:\Users\Tom\AppData\Roaming\Kodi\addons\plugin.dbmc\resources\lib\sync\syncfile.py", line 86, in sync
self.updateTimeStamp()
File "C:\Users\Tom\AppData\Roaming\Kodi\addons\plugin.dbmc\resources\lib\sync\syncobject.py", line 104, in updateTimeStamp
st = os.stat(self._localPath)
WindowsError: [Error 123] The filename, directory name, or volume label syntax is incorrect: u'special:\\masterprofile\\addon_data\\plugin.video.salts\\settings.xml'
23:06:19 T:13084 NOTICE: plugin.dbmc: Number of items synchronized: 1 (AF TV)
Any idea why I can't sync this properly??
I am trying to understand the "sync" concept within this addon. I had it set to Sync = on but found my USB stick (I am using OpenElec) almost full with synched Dropbox content.
What I want is to be able to just stream the content from Dropbox. But when I turn Sync = off then I see no files in the addon.
Am I missing something?
Trying to use this plugin at the office so all of our designers can drop their mockups a in a folder, and we can view them on the big screen in the conference room. It doesn't seem to want to display any images, though. When I navigate to a folder with images, it does the caching, and as I scroll through the list, it shows the thumbnails, but if I click any of them, it doesn't open the image. Videos work great, though. Any ideas?
Edit: opened the plugin from under the Pictures heading in kodi, and they load now
suddenly today DBMC fails to playback any video. I've tried on different devices still the same issue, can't play back any video.
Now I go to setting and and untick " Stream video and music media (don't catche), then it can playback the video, but keep catching and often cause video stop playing.As before I ticked that option and it worked just fine, I don't know why today it stops working.
Now I tried another account, I ticked the option " Stream video and music media (don't catche)", the playback works fine. What's going on here?
Hi All
I was able to install and sync my drop box account to DBMC. However, I can only see my folders and not the content i.e. cannot see my photos or videos?
Any ideas?
Hey, first of all thanks a lot for this addon, it works great. Made an account to ask if it would be possible to add the ability to tag files within the addon as it would be really helpful for navigating around if you have a lot of files. The standard Kodi search feature will only search the names of the files that are showing (so none of the ones that require you to hit "Show me more..."). Right-clicking a file gives you the addon's search feature but it's still limited to just the file names. It's fine if it's not possible to add tags in the addon, I'll live, but it would be a great feature if possible.
