2013-09-07, 09:26
Problem: My TV Show folder won't remember what media type it is so none of my season artwork shows up.
When I go to my Movies folder and open the left-side display menu (by pressing ▲) and then the content menu (by pressing ◄), the content type is set to Movies. When I go to my TV Shows folder and repeat the process, the content type is again set to movies.
Even when I manually change the content type from Movies to TV Shows (which does fix the problem and make my season artwork show up), it resets itself the next time I open the TV Shows folder.
My library is in good shape and I've had no trouble scraping. The Movies and TV Shows links on my home screen link directly to corresponding video folders which works well too. I'd really like to know why XBMC or Aeon Nox won't remember that my TV Shows folder contains TV shows and display the right artwork!
Any help with this issue is greatly appreciated.
Thanks,
Matt
Thanks,
Matt
